MASTERCOOK COOKING LIGHT INSTALATION PROBLEM
WHEN I TRY TO INATALL PROGRAM IT STARTS
THEN SAYS INTEGER DIVIDE BY 0 ERROR I AM
USING A PEN 4 WITH WIN XP . THIS PROGRAM
LOOKS GREAT .HOW CAN I USE IT ?
RM
    Scholar:
  • 65 Answers
When you purchased the program was it designed for win98, xp, or vista?ti sounds like you may be using an incompatable OS. What exactly is a PEN 4? is it something to write on the screen? The software may be picking the pen up and doesn't support the pen.. try unplugging it if it is a PNP item.. You may want to goto the software site and see if there is an upgrade or a patch that you can download Hope that helps a little at least
Posted on May 22, 2009
How do i factor numbers on a ti-30xs calculator
This calculator does not have a key that you can use to find the prime factor of an integer.
You can however use the calculator to find the factors
1. If number is even divide it by 2
Keep dividing by 2, while keeping track of how many times you divided by 2.
If you divided 5 times by 2 before getting an odd number, then your first factor is 2^5
2. Now try dividing by 3, keep track of the number of times you divided by 3 before you could not divide by 3 any more. If you divided 0 times by 3, your second factor is 3^0, or 1 and 3 is not a factor.
If you divided 4 times by 3, your second factor is 3^4
3. Divide by 5, until you can't any more. Keep track of the number of times you divided by 5.
4. Divide by all other prime numbers 7, 11, 13, 17, 19, 23, 29, 31, 37, 41, etc. For each prime number, keep track of how many times you divided by it, until you could not any more.
Example: 23100
Division by 2
23100/2=11550 ---------> 1 division by 2
11550/2=5775 ----------> 2 divisions by 2
Note that 5775 is not divisible by 2. No more divisions by 2.
First factor is 2^2
Division by 3:
5775/3=1925 ----------> 1 division by 3
1925/3=641. 66667 Not an integer. No more divisions by 3.
2nd factor is 3^1
Division by 5 (number ends in 5)
1925/5 =385 -------> 1 division by 5
385/5=77 ----------> 2 divisions by 5 and no more (quotient does not end in 0 or 5)
3rd factor is 5^2
Division by 7
77/7=11 --------> 1 division by 7, and no more
4th factor is 7^1=7
Division by 11
11/11=1
5th factor is 11^1=11
Assembling the factors 2^2, 3^1, 5^2, 7, 11
Prime factorization of 23100 is
23100=(2^2)(3)(5^2)(7)11
Dec 18, 2013 | Texas Instruments TI-30XA Calculator
When I try to open a cookbook I get a dialog box saying Unable to create view: 'cbks'-'open'
I started receiving this same message today also. In addition, when I do a search by ingredient in the Search feature and try to open up the recipe I get the same message with the words 'Rcpe' - 'open' instead of the 'Cbks' - 'open'
Aug 06, 2013 | ValuSoft MasterCook 11
Can't install program
If it starts to install and then crashes try running the install program in Compatibility mode with a previous version of Windows. Most of the time when I run into this it is a compatibility issue. If your CD drive is not reading teh disk then the problem is the CD drive or CD itself.
Dec 03, 2011 | Vivendi Mastercook Cooking Light 4.0 Full...
I have a software discs i us ein a windows 95 Operating stystem.. My newere PC Windows VISTA willnot allow MasterCook - Suite Version 4.0 install- Error interger 0
Too many differences between Vista and Win 95 to run it straight. Insert the disk and when the auto run comes up tell it to display contents in Explorer instead. From there find the setup file and right click it in the explorer window then select the properties for that file. From that window you should find a tab with an option to run the program in Compatibility Mode select that and then select Windows 95 or Windows 98 and you maybe able to run the program. Sometimes it is just too far out and you will have to find an upgraded version. Another option would be to check the publishers website for a patch or fix for using the original program.
Feb 15, 2011 | Computers & Internet
The following appears whenever I try to print a recipe MASTERCOOK APPLICATiON HAS STOPPED WORKING A problem caused the program to stop working correctly. Windows will close the program and notify you if...
If you have the install media (cd or dvd) uninstall it and try a fresh install.
You may get it working by using system restore to turn your pc back to when it last worked.
Start / programs / accessories / system tools / system restore
Sep 21, 2010 | ValuSoft MasterCook Deluxe 9.0: Windows
MasterCook 6.0 will not open up
It Took Me About 40 min. to figure it out
1. install master cook 6.0
2. open sierra on c drive c:\sierra\mastercook6\program
3. delete msvcp.dll file
mastercook 6.0 will now run
there will be no cookbooks
1. goto file\open add it will list all the cookbooks
2. open each one and then everything works as normal
Apr 11, 2010 | Sierra Master Cook Deluxe 5 Full Version...
I cannot open mastercook 5 without getting this error when trying to open. I am using Windows 7 64 bit.
Hello and thank you for using Fixya's services.
Unfortunately, Mastercook 5 is not compatible with Windows 7. There may be a work around but the only work around I found was for Mastercook 9.
From what I understand, it has been difficult for many to install Mastercook 5 & 6 on Windows Vista.
I did, however, included a link to MasterCooks blog in hopes that it can assist you with a work around.
Maybe the work around for MC9 in W7 will work for your version?
http://mastercookinwindows7.blogspot.com/
Hope this helps and please let me know if you have any questions.
Dec 04, 2009 | Vivendi Mastercook Cooking Light 6.0 Full...
When installing MC9 on my Vista machine I get the following "Error 1904.Module C:Program Files (x86)MasterCook 9ProgramMCWrap.dll failed to register. HRESULT -2147220473. Contact your support personnel."
Are you installing as administrator?
you could try:
Start->run
and type in the following line
regsvr32 "C:Program Files (x86)MasterCook 9ProgramMCWrap.dll"
or wherever the .dll path was
then try reinsalling.
When I installed it, I right clicked on the install file, and clicked RUN AS ADMINISTRATOR.
Try reading this:
mc6help.tripod.com/mastercook_and_vista.htm
Sep 17, 2009 | ValuSoft MasterCook Deluxe 9.0: Windows
Error when installing mastercook 6 on my vista laptop
hi there.
mastercook 6 runs on older windows versions
like win95, win98 and win Millenium Edition
only, newer are not supported.sorry
MasterCook deluxe 9.0 supports win2000, XP and VISTA, but this would mean spending another 19.99 on amazon.
you could try to install the 6.0 version on an older machine that still has win98 on it or think about setting up a multi-boot system (u need some computer expertise)so you can install multiple operation systems on your laptop, but this takes a lot of effort and all the drivers for your computer for win98, so spend of whatever you have more of, time or money...
good luck!
Aug 07, 2009 | Vivendi Mastercook Deluxe 6.0 (71052) for...
Need help in Special Formatting Number
Here is one solution. You might consider adding more robust error handling.
if the decimal numbers passed to the div function are multiples i will be a non-zero number of that multiple otherwise i will be zero.
Dim i As Integer
i = div(12, 0)
If i = 0 Then
'not multiple
' do this
Else
' is multiple
' do something else
End If
Function div(ByVal numerator As Object, ByVal denominator As Object) As Integer
dim n , d decimal
Dim result As Decimal
Dim remainder As Decimal
If IsNumber(numerator) Is True _
And IsNumber(denominator) Is True Then
If numerator <> 0 Then
n = numerator
d = denominator
Else
GoTo error1
End If
Else
GoTo error1
End If
result = Decimal.divide(n, d)
remainder = Decimal.remainder(n, d)
If remainder = 0 Then
div = result
Else
div = 0
End If
Exit Function
error1:
msgbox("Numbers must be non-zero numerics", , "Multiple check error")
div = 0
End Function
End Function
Aug 06, 2008 | Computers & Internet
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
