Question about EnGenius EAP350 - wireless access point
Add password for wireless users
Yellow sheild icon by wireless connection
No wireless connection or a connectivity problem with it. May be user name password mismatch? Add your wireless modem id and password again in the wireless settings in the general settings section. If your wireless modem id is in there delete or forget this net work. Search and add again.
May 11, 2014 | Cell Phones
Forgot user name and password need to add new
Sorry but this is the only to reset the password
Press the Reset Button for approximately 10 seconds
Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
Jun 06, 2011 | Linksys Wireless-G WRT54G Router
I have no internet connection with the router but can surf without the router and only my modem
You need to configure your router WAN settings as your internet service provider.
If your ISP gives you static ip then configure it as static.
If ISP gives user name and password to connect inteernet then configure router as pppoe.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings enable wireless then WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.If you are able to see password in * or # then you need o add new password but if you are able to read it then note down it then you can connect with it.
If you are not able to access router with above ip and user password then press RESET button for 10 seconds it is in back side of router.
Then you can access it with above method.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 13, 2010 | NetGear WGR614 Wireless Router
HELP I NNED TO UNLOCK A D LINK 246OR ROUTER
http://192.168.0.1
or
http://192.168.1.1
Jun 06, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
How can i made admin password in WBR 2310?
in your explorer bar
type 10.0.0.1
log on as ADMIN
Password Admin or 1234
add new user when logged on
create your password here
make new user the default user
'write down log on details and password too
open a second explorer bar and log in as new user for testing
if working save your settings and close explorer
open in admin mode then try new user mode
admin probably wont work now new user is the default user so everything should be working now
cheers Misterdj
Apr 18, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I just want to change my router password..its wag200g.. can you tell me please?
If you have forgotten your wireless security password then you need to add new password because it is saved in * and # format so you need to add new code.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Apr 16, 2010 | Linksys WAG200G Router
I need to password protect my router.
log on to the modem as ADMIN
Add A NEW USER
Then add password for new user
(write down the new user & password info)
save your settings
Test away
Rate Me Please MISTERDJ
Apr 10, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
I have lost the password for my LIVEBOX C640 router on orange. I am connecting a new NETBOOK but it keeps asking for the password. My original laptop still operates on the router wireless
http://192.168.0.1
or
http://192.168.1.1
Apr 05, 2010 | Computers & Internet
Loading belkin G adaptor
give the default user name and password.
if that does not work please reset the device and use the default user and pass.
thank you
Dec 29, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Router
http://192.168.0.1
then type user name:admin
password is:admin or blank
thaen go toa dvanced then wireless management.then add mec addresses.of your computer which u ewant to add.
go to your computer then run cmd
then u get command prompt.thenh type "ipconfig /all"
u get mac addreses.
add it in router.
Nov 11, 2008 | NetGear WGR614 Wireless Router
EnGenius EAP350 - wireless access point Logo
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
