Question about AOC 917Sw 19" LCD Monitor
Monitor resolution not listed, Driver update issue
I use Windows XP Pro. Instructions on this new AOC 917sw says to set the resolution to 1440 x 900. This is not listed. The closest numbers listed are 1400 x 1050 and when that is selected the monitor displays an error message that says it's not supported. I do see a display with the 1024 x 768 setting, but the image appears stretched across the screen. However the display appears clear with this setting.
Following the instructions with the new monitor on setup of drivers. The procedure won't find a better driver on the CD than the standard driver that was installed for a previous monitor. See notes below:
    1. Start Windows® XP
    2. Click on the 'Start' button and then click on 'Control Panel'.
    3. Select and click on the category 'Printers and Other Hardware'
    4. Click on the 'Display' Item.
    5. Select the 'Settings' tab then click on the 'Advanced' button.
    6. Select 'Monitor' tab
    - If the 'Properties' button is inactive, it means your monitor is properly configured. Please stop installation.
    (YES - PROPERTIES BUTTON IS ACTIVE.)
    - If the 'Properties' button is active, click on 'Properties' button.
    Please follow the steps below.
    7. Click on the 'Driver' tab and then click on 'Update Driver...' button.
    8. Select the 'Install from a list or specific location [advanced]' radio button and then click on the 'Next' button.
    9. Select the 'Don't Search. I will choose the driver to install' radio button. Then click on the 'Next' button.
    10. Click on the 'Have disk...' button, then click on the 'Browse...' button and then select the appropriate drive F: (CD-ROM Drive).
    11. Click on the 'Open' button, then click the 'OK' button.
    12. Select your monitor model and click on the 'Next' button.
    - If you can see the 'has not passed Windows® Logo testing to verify its compatibility with Windows® XP' message, please click on the 'Continue Anyway' button.
    13. Click on the 'Finish' button then the 'Close' button.
    14. Click on the 'OK' button and then the 'OK' button again to close the Display_Properties dialog box.
Result: I managed to work around and select the 917sw driver from the disk, which was installed. However it still does not list the 1440 x 900 resolution.
I have a clearer image using the "Default" display and the Microsoft default driver.
  • 2 more comments
  • Tom Bl May 20, 2009
    Yes. In this case the video is integrated in an Intel mother board, model DG45ID.
    I'm hoping to find the correct resolution for the monitor that gives me as clear an image as the 1024 x 768 but that does not appear stretched across the screen.
  • Tom Bl May 22, 2009
    I did use this download and the updated files. I thought this would give me the 1440 x 900 option. which is apparently the native resolution of the monitor. However the selections were the same as before.
    I'm now fairly satisfied with the clear image I get from the Windows default driver, and will probably use the monitor that way.
    I installed the files associated with the above download. The resolutions listed still does not include 1440 x 900, which is apparently the native resolution of the monitor.
    My present settings stretch the video across the screen. This means a round image comes out looking oval.
  • Tom Bl May 23, 2009
    After following this update I still did not see the quoted resolution on the list. I am continuing to use a resolution setting that gives me a clear image but where round objects appear oval.
    Novelist:
  • 118 Answers
My compliments. Your description of your problem is great. I know what you've done and I understand your problem.
However, I am wondering about a few things that may help you. the video settings that you are referring to in your description are dictated by the software that drives the video card, not the monitor.
Are you sure you have the latest Manufacturer's drivers for your video card?
I don't see any mention of the video card here.
good luck
tony
Posted on May 20, 2009
2 Suggested Answers
rcw1962
  • 2571 Answers
SOURCE: I have installed Windows 7
Download the correct graphics driver.
If you have a Graphics card, download the driver from either Nvidia or ATI.
If your graphics chip is on the motherboard, download the driver from your manufacturers support page
Posted on Aug 05, 2010
Aoc monitor shows error message while connecting with i ball tv tuner
What resolution is the AOC monitor capable of using?
What is default resolution of the device you are connecting?
If the default is 1080P and the monitor is not 1080P capable then that would be your problem. You could attach to another monitor or HDTV and possibly turn down the resolution then try again.
Feb 05, 2016 | AOC 917Sw 19" LCD Monitor
AOC 917sw starts normally then goes black after a few seconds?
More than likely, you have set the resolution too high for the monitors capabilities. Set the computer to a lower resolution, and try again. If using windows, try to boot in safe mode to accomplish this. Other OS's can take variables at boot also to do the same. You'll have to search for yours.
Good luck.
Bruce
Jun 08, 2014 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Plz help me to set my aoc 19 inch lcd for operating system windows 7
Settings are dependent on video card not OS. Try changing resolution to different scale.
Aug 27, 2012 | AOC 917Sw 19" LCD Monitor
We have purchased two e950Sw LED 18.5 monitors to replace the crt monitors on two of our computers. Old monitors worked fine. Both of these monitors when hooked up get the "No signal" message....
Your old monitors might have had a higher screen resolution or and incomparable resolution for your new monitors.
Probably the easiest way to get them to work is to plug the old monitors in then go to your control panel / display and set the resolution to 1366 x 768 as this is the native resolution of the e950Sw LED.
Chris
Jul 08, 2011 | Computers & Internet
Can't find AOC LM725 driver for XP
click here to download the latest drivers you required.
May 12, 2010 | AOC 917Sw 19" LCD Monitor
Screen is too bright. How do we turn down the brightness?
There should be a menu button on the monitor it self, which will give a list of options, one of which should be brightness.
Also, windows 7 has a built in brightness setting -- search for calibrate display color
Apr 07, 2010 | AOC 917Sw 19" LCD Monitor
Remove banner "input not support" in 19" wide LCD 917Vw monitor. i am working different operating systems development some i try to excute some work this banner will appear pls help me..
You PC video setting is too high for the monitor to support, you need to set the PC resolution to 1440 x 900 @60Hz, try that first. Here is the spec for your monitor: http://reviews.cnet.com/lcd-monitors/aoc-917sw-lcd-display/4507-3174_7-33109821.html?tag=mncolBtm;rnav
Unless there are problemswith the logic board in the monitor if the resolution is already set correctly.
Mar 17, 2010 | AOC 917Sw 19" LCD Monitor
I am getting a INPUT NOT SUPPORT message for my 917sw AOC lcd monitor. It does work on safe mode I am using windows vista, but when I come back to normal mode, I see the same message again... HELP!!!
The resolution selected in normal mode is not supported by your monitor.
Instead of booting into safe mode, boot into VGA mode - this should allow you to change the resolution - change it to one that works and then you should be able to use normal mode.
Hope this helps, Sherwin
Dec 21, 2009 | AOC 917Sw 19" LCD Monitor
On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
Aug 29, 2009 | AOC 917Sw 19" LCD Monitor
AOC 917sw 19 inch monitor resolution issue (same as above)
Have you try the following resolution values:
1280 x 768
Usually its the standard for widescreen view
Please don't forget to rate if answer is useful
Jun 18, 2009 | AOC 917Sw 19" LCD Monitor
AOC 917Sw 19" LCD Monitor Logo
884 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
