Question about Fujitsu fi-6010N Sheetfed Scanner
Scanner initialization has failed - Fujitsu fi-6010N Sheetfed Scanner
30.01.34 scanner failure 9050
Scanner initialization failed, and the copy processor
board (CPB) is not communicating
with the scanner-controller board (SCB).
1. Turn the product off, and then on.
2. Check the scanner controller board
LEDs.
3. Check the connections to the scanner
controller board.
4. Replace the scanner controller board.
Jul 30, 2014 | HP Office Equipment & Supplies
Fail to initializing
The fail to initialize is typically a problem with the document scanner...but not always. here is a quick test you can try. Turn the unit off then power it on again. Slightly lift the copy lid as the unit goes through warm up mode...pay attention to the light color emitting form the scammer. it starts to blink red, then changes to a bright white IF the scanner is working properly. IF the scanner is NOT working properly the scanner stays RED during the warm up.
Nov 26, 2013 | HP LaserJet Pro M1212nf MFP -...
After I enter a frequencie the enter button doesnt work to enter
If all else fails, you can RESET or INITIALIZE the scannerto bring it back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 then 1 while "Welcome to Dual Trunking" is displayed.
- "Initializing Please Wait" will appear for about 2 seconds.
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Feb 19, 2010 | Radio Shack Pro-95 Handheld Scanner
MY 2096 BASE SCANNER READS ALL CHANNELS LOCKED AND I CAN'T UN DO IT AND OPERATE NORMAL. HOW DO I CORRECT THIS PROBLEM?
If all else fails, and it sounds like it has, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
BillB
Jan 24, 2010 | Radio Shack Pro-2096 Base Scanner
All channels locked
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
BillB
Jan 23, 2010 | Radio Shack Pro-95 Handheld Scanner
My pro-2096 does not display any letters or
To RESET:
- Press ENT
BillB
Jan 22, 2010 | Radio Shack Pro-2096 Base Scanner
All channels are locked out. how do I get them unlocked
To RESET:
- Press ENT
BillB
Jan 22, 2010 | Radio Shack Pro-97 Handheld Scanner
I TWON'T MOVE. IT SAYS ALL CHANNELS LOCKED OUT. NEED HELP
If all else fails you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Press ENT
BillB
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
Failed to initialize
Pull the battery out, press the trigger for 5 secs and you are done
Apr 25, 2008 | Zebra Symbol Technologies MC909X-G Series...
Open Questions:
Fujitsu fi-6010N Sheetfed Scanner Logo
258 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
