Question about LG Heating & Cooling
Fan slows to about half speed when heat cycle kicks in
I have a 7000 btu LG heat/cool window unit. When using heat mode, fan runs continuous and when heat kicks in the fan slows to about half speed. Could problem be loose neutral connection? Or does the ac need a dedicated 12-2 wiring, unit is about 17 feet from breaker box.
  • LG Master
  • 3,361 Answers
The heat fan speed is slower than the cooling speed. About 300 rpm less.
You may not have a problem.
Posted on May 20, 2009
  • 148 Answers
The fan runs at a lower speed for heat with a/c it has to move the air at a higher speed
Posted on Jun 26, 2009
I have a airwell GC-30RCC when put on heat the fan on the indoor unit wont kick in it works fine on cooling and plain fan mode but not on heat mode the red fan light is on too
How do you get it to kick in ?.Fid you spin it by hand ,if that's what you did and fan runs then you have a bad capicator. If fan runs fine in cooling and not in heat then you have a bad board
Jun 01, 2017 | Heating & Cooling
No heat but fan keeps running
If the air conditioner compressor runs all the time the main control board might be defective. The main control board provides the voltage to the fan motor and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Nov 25, 2013 | LG LAN186HV / LAU186HV 18,000 BTU 15 SEER...
It is 106 degrees outside, I have a a/c unit which is cooling at 75 degrees in a 1180 square foot townhouse apartment, this seems like the unit is doing all it can with the excessive heat, is it
Unfortunately, 7000 Btu's will not cool 1180 sq ft. At best, it's rated for 400 sq ft, as it's only rated as a "Room Air Conditioner". To cool 1180 square feet, you'll need at least 30,000 Btu's (like in Central Air Conditioning) or 4 more window units spread out throughout the condo. It takes more Btu's to cool, than it does to heat.
I really sorry. I wish I had better news for you. Thanks for choosing FixYa.
Aug 02, 2011 | LG Heat cool Window Air Conditioner
Have an lg reverse cycle was sitting for 12 months. the fan works fine but cooling or heating is not working.when i first turned it on it took about 5 minutes then compressor kicked in once in got to...
I think, your compressor gets over heated due to condenser block-clean it. Less rpm fan speed. -Replace capacitor. 3.Check compressor running capacitor. If weak replace it. Helpful?
Dec 29, 2010 | LG Heat cool Window Air Conditioner
I RECENTLY INSTALLED 3 LG INVERTER MINI-SPLITS.TWO 12,000'S AND ONE 24000 BTU.THE 12'S SEEM TO WORK GREAT THROWING NEARLY 140' HEAT. THE 24 IS LUCKY TO THROW 90' HEAT AND I DON'T SEEM TO BE ABLE TO CHANGE...
I think you keep in Auto mode. If in Auto mode, you can't change fan speed. Keep in cool/heat mode and then press fan button in remote to select desired speed.
Dec 16, 2010 | LG Heating & Cooling
Fan does not run
fan motor going drawing too much amps
Aug 14, 2017 | Whirlpool ACS072XJ Air Conditioner
My LG 7000 BTU Heat / Cool Window Air Conditioner does not cool and the fan speed F1 will not work. Fan runs on F2. The heat works fine. Any suggestions?
You have a control board issue. You can get a new control board by Google searching the make and the model of the unit. There are several sites that sell them
May 24, 2010 | LG Heat cool Window Air Conditioner
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
May 16, 2009 | Fujitsu 24R1 Air Conditioner
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
Heating & Cooling Logo
229 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
