Question about Garden
Will not start normally
Weed wacker will not start when using the primer bubble but will start if spark plug is removed and gas is added into [plug hole. changed fuel filter with no results.after machine is running and then shut off starts up right away. can't figure it out. Help it's driving me crazy
echo trimmer/brush cutter model srm210
  • 10,865 Answers
Your carbeurator has crud in it from leaving gas in it over the winter.
You may be able to clean it using a carbeurator cleaner spray which you spray into the air intake after you remove the air filter, OR by using a gas additive such as seafoam which will clean the carb. as it runs. If you have any old gas in the tank of your weedwacker, discard it. Same goes for your portable gas tank. Gas deteriorates over the winter.
Posted on May 20, 2009
My carburetor the bubble pulls up gas but weed eater will not start
check that the stop circuit is allowing spark at the plug
check that the engine is not flooded form over use of the primer
IT actually squirts fuel into the engine if over used when the primer is full
Jul 01, 2016 | Garden
How to test a wweedwackers magnito
Use a spark tester and place it between the spark plug wire and the spark plug. Pull the start cord and see if there is spark to the plug. Hope this helps.
Jun 28, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
My weed eater lower start reasonably well, but shuts down after running less than a minute
SOUNDS LIKE YOUR MAGNETO IS BAD,, TO FIND IT JUST FOLLOW THE SPARK PLUG WIRE THERE IT IS,, HOPE THIS HELP
Oct 17, 2013 | Weedeater 25cc Gas Blower ()
Help my weed wacker string
Pull the spark plug out and try pulling it over if still won't move might have seized the motor possible not enough oil in gas You can try if not to much damage done pour some kerosene or stove oil down spark plug hole let sit over night try again
Jun 08, 2013 | Garden
Stihl FS85 starts fine, But not take full throttle
Pumping the primer bubble while the engine is running should cause the engine to over fuel and stall (if the tuning is correct). Sounds like its not fueling enough, pumping the primer is forcing fuel through the carb causing the engine to pick up rev's, but this is soon exhausted which is why it wont rev on the throttle.
* Check that the fuel line is not damaged and drawing in air. (if this is intact try the next step)
* Strip and clean the carb. Replace any diaphrams if needed.
* Check gaskets seal between carb, air filter and cylinder.
Just out of curiosity what standard carb settings did you use.?
May 23, 2013 | Stihl FS 85 Weed Eater
Weed wacker wont start
Try a new spark plug or checka and see if it is getting fuel
Jul 18, 2010 | Troy Bilt Tb70ss Gas Trimmer
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
2-cycle toro weed wacker does not start
Sounds like the flywheel has come loose and sheered off the key which locates it on the crankshaft without this the timing will be out ,
Jul 17, 2009 | Craftsman 25cc Gas Line Trimmer
DOES NOT START
does this trimmer have a primer bulb?? if so this is a good place to start.some of the primer bulbs on trimmers and chain saw engines after time develope pin holes take a flashlight and magnifiying glass and inspect it . if it is fine check and make sure the filter screen in side the tank attatched to the gas feed tube is not plugged also make sure the tube itself is not pluged or pinched. if none of these solve the problem make sure the flywheel does not have a coat of rust ,dust ,or debris on it also check kill switch for short or bad wires hope one of these sugestions gets it fixed for you.. (note)when you remove primer bulb for inspection check at same time that the oriface that the gas pumps through is not plugged...one more thing start with the easiestand least expensive and go from there. have a great day mrdmburns@cableone.net
Apr 25, 2009 | Garden
Garden Logo
317 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
