Question about Goodman GMS90703BXA Heater
I need the condenser tonnage of a Model # GMP 100-5. Can you help?
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
NEED TO KNOW THE TONNAGE ON THIS UNIT
2 1/2 ton. home is about 1200-1400 square feet ?
Apr 18, 2016 | Ruud Matching Split Air Conditioner
What are the tons of a RUUD AC HANDLER MODEL UBHA-17J11 SO SFFA SERIAL NUMBER MOO500 03485 and what type of CONDENSER & TONS CAN IT HANDUE WITHOUT PROBLEMS?
You can find the tonnage in the model number which increases by increments of 12, so if the model number is 24 =2 tons. Model number on your a/handler is 17. Thats a ton and a half. Really should match the evap and condenser for the best efficiency. ...
Sep 24, 2015 | Ruud Heating & Cooling
Water is leaking from the evaporator pan beneath the coils down the inside heater wall and onto tje floor. The condensate pipe is clear. The pan is not accessible within the sheet metal box sitting above...
Hello, if the condensate pipe is clear then most likey the pan is cracked, onlynway to acsess thenpan is by opening up the plenum by cutting into it with sheet metal tools.
Aug 22, 2011 | Goodman Heating & Cooling
Need to know tonnage of goodman condenser model # ssz140361ab
If this is the correct Model number, you have a 3 ton unit. 036=36,000 btu. 12,000 btu per ton.
Shastalaker7
A/C, & Heating Contractor
Apr 01, 2011 | Heating & Cooling
Trying to find the tonnage of my goodman a/c model number aruf486016ba
Does this happen to be the number on the indoor blower coil. The 4860 would either be set up to handle either 4 or 5 tons. If this is so, you need to look on the outdoor condenser to see whether a 4 or 5 ton condenser was coupled to the unit.
Mar 20, 2011 | Coleman Heating & Cooling
Hello, I bought the 32 ford model kit from Gmp but the instruction manual was uncomplete. the only part that was described is the steering mecanism. i want a manual for the whiring of the engine. ...
Hi there yes thats all you get if you read the boz it will say the instructions are brief and that you need to have a good knowledge in 32fords and hotrods i studied loads of pics for mine and when its done with an exelaxant paint job its a very rewarding model.
just think that the manufacturers in china they have the same instructions as you get, a few pics they have to learn to build them to.
hope this helps if you would like more on gmp help please do contact me at austintant@hotmail.co.uk put your subject as gmp
Mar 18, 2011 | Ford 1932 Ford Two In One Model Kit 118 By...
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
Need to verify tonnage of unit
In almost every case, most manufacturers put the tonnage in the model number. Look for something that is divisible by either 6 or 12. Something like, 24, 30, 36, and so on. Cfm has to match the tonnage. Usually in the neighborhood of 450 cfm per 12,000 btu's of cooling for the inside of the structure.
Hope this helps.
May 08, 2009 | Heating & Cooling
I NEED INSTALLATION INSTRUCTIONS FOR A GOODMAN FURNACE MODEL GMP-100-4
purchased an Coleman Mach 3 from a friend. Need installation instructions on how to install.
E-Mail - gregoryc2@comcast.net
Aug 17, 2008 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
27 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
