Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Oil in air breather
Vanguard v twin briggs and stratton too much crankcase pressure pushing oil up through the crankcase breather into the air breather. Just replaced one blown head gasket, adjusted valves both sides, new fuel pump, problem worse, HELP, please mower runs great but after mowing for 10 minutes there is approximately one tablespoon of oil in the air breather.
  • 3 Answers
Sounds like you have too much oil in the engine (should normally be around 500-600ml when there is too much oil, it gets past the piston rings and pushes it through to the head.
Posted on Jul 09, 2009
18hp v twin brigs when it runs oil comes out of carb
you will see a tube coming from engine block to carb, pull it loose at carb just under the air intake or right behind breather filter. start engine and if oil blows out then its a blown head gasket.
Jun 21, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Oil leaking into air filter
You are getting what is called blow by. Which happens when there is to much oil in crankcase or an oil ring is bad in engine
Nov 02, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Getting fuel in oil on 19hp b&s motor. Cleaned carb and drained oil, fresh oil and started motor, motor ran for 3 or 4 minutes then had to use a little choke to keep running and then it started...
How long did it take to do this job..did you clean the the carb first...then the oil or vise versa...the reason I as is ma y if these motors are equipped with an electric valve on the carb that go bad or stuck allowing the gas to continue flowing after shut down eventually in the intake valves and into the crankcase...causing smoke and high crankcase pressure and out the carb and exhaust...no use changing it WILL happen again..the fix is simple put an inline gas shut off and shut it off if only shut down for minutes...happened to my 18 horse Briggs...just shut it off every time you turn the engine off..Hope this helps..good luck..
Sep 08, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
16 h v-tech briggs-stratton is blowing oil into carburator, what could cause this problem and possable solutions
see if the oils coming out of the rubber hose by the air cleaner ,if it is it could be the pcv valve the rubber hose is connected to. order could be too much oil in the engine, sometimes the carburetor will flood the crankcase with gas , you have to rebuild the carburetor and change the oil.
Feb 18, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
18 hp v twin will not run. It is gettng fuel to carb but will not run. It will run when you spray starter fuel in carb but does not continue to run.
There is a solonoid valve in the carburator that shuts off fuel to meet emissions standards. Be sure it is wired to be powered when key is in run position. You can hear a "click" at the carb. when the solonoid powers up.
Jan 08, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
My 18 hp vanguard is making oil,( oil level is rising) is not carb as it starts and runs good. any chance of bad fuel pump?
if the diaphragm in the fuel pump gets a small hole in it , it will still run, but **** fuel into the crankcase, the fuel pump is serviceable, and easy to rebuild, a new diaphragm kit is fairly cheap at any local saw shop, just remember to take the model number off of the engine so they can look it up, and sometimes its a good idea to take the pump in with you to match it..
Aug 20, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have an 18hp v twin vanguard and it is
Piston rings being wore.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
4,668 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
nirodacyar
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
