Question about ViewSonic VA2026w Monitor
My sidebar clock is eggshaped
Got a new veiwsonic widescreen monitor,and cant get it to look right.everything looks short and fat(sidebar clock is eggshaped)model # is va2026w, everything looks like its bein pressed down on and when i change the resolution,to the highest where its suppose to be, the picture is in the middle of the screen with blackbars on the side(like it a 15" in the middle of the screen,but the graphics are great( clock is round) what is causing this? can anyone help?
  • abbeezwax May 20, 2009
    how do you do that
  • Serwen Bagadiong
    Serwen Bagadiong May 11, 2010
    check the maximum resulotuin of your video card
5 Suggested Answers
faheemsafdar
  • 68 Answers
SOURCE: New widescreen Monitor
You should download latest graphic card drivers from this link below
http://ati.amd.com/support/driver.html
Posted on Feb 27, 2008
  • 3278 Answers
SOURCE: 1440x900 Monitor seems to think it is a 1680x1050 screen @ >19"?
Try reinstalling the video driver (Control Panel - System - Device Drivers - Video ... ) Good luck
Posted on Jun 13, 2009
budmrtn
  • 11361 Answers
SOURCE: Extremely Dim/Dark ViewSonic Monitor
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
  • 150 Answers
SOURCE: My Viewsonic VG2230wm refuses to use its native
You will need to adjust your monitor settings in the NVidia control panel. You can get to this by right clicking somewhere in a blank spot on your desktop and then selecting it from the menu. You will want to go into the Display section. If you aren't able to see that section, change from "Standard" to "Advanced" settings at the top of the screen.
Posted on Dec 31, 2009
I bought a new hp 20" lcd widescreen monitor, but my computer is 6 years old, a compaq presario sr1030nx. as you probably guessed, the images on the monitor look short and fat. my video card spec...
you can change the monitor resolution settings by right clicking anywhere on your desktop, then click properties. Try changing the settings until you find one you like. If you pick a setting that your computer and/or monitor cannot do, it will reset to the last setting after a few seconds. When you find one you like, click ok. You can change these settings anytime you want.
Aug 22, 2011 | Computers & Internet
Switched to a widescreen monitor and the resolution is faded and lacks sharpness. How to reslove it?
depends on what version of windows you are running, but for the most part, right click on the your desktop, go to properties, then click on settings i think at the top. Then play with your resolution till it looks good. If you cant find one that looks good, your video card might not support the monitor you have, and you might need to buy a new one.
Feb 09, 2011 | Computers & Internet
The pictures are too wide all people look fat
You most likely have a wide screen and the screen resolution needs to be adjusted to suit the monitor.
Go to the Control Panel - Display and adjust the screen resolution until you get a normal image and correct screen aspect screen ratio. Start with a screen resolution of 1024X768 and gradually increase it until you get an image that suits your screen.
Oct 01, 2009 | Acer Computers & Internet
Veiwsonic VA1912WB flashes then goes blank
You have a very common problem that happens to many LCD monitors after 2-3 years of use. Your monitor has blown the power supply that controls the backlight bulbs. Go to our web site at: www.ccl-la.com/badcaps.htm and look at the pictures of what blown capacitors look like. Open the back of your monitor and replace any of the parts that look like the ones in the pictures and you should be back going again. Be sure to usehigh temp (105c) replacements. Resolder them in with the side polarity stripe going the same direction and the old one came out. The values of the bad parts will be marked on the sides of the ones you take out, they can be ordered online from us or several other places, the one from Radio Shack are not suitable for use in the high heat inside on the monitor and will soon blow again.
I hope this helps, if so please rate my solution.
If you have more questions just ask.
Buddy
Corporate Computer
www.ccl-la.com
Sep 12, 2009 | ViewSonic VA1912WB 19" WideScreen Monitor
Wide screen images lookshort and fat
Native resolution for a 17" widescreen TFT is ;
1280 x 800
Try that.
(The 1440 x 900 is for a 19" widescreen)
Dec 31, 2008 | KDS K717s 17" LCD Monitor
Distorted images due to wide screen
Hi
Your entire desktop is probably stretched left to right.
You need to adjust the resolution of your computers video card in the display properties to one that the widescreen will accept correctly.
There is a chance that your video card may not have the correct resolutions available. If this is the case then you may be stuck with this view until you change coputers or video cards.
to get to display properties based on win2k or xp
Right click in the center of your desktop, choose properties, go to settings and there you should see the resolutions available. Try different ones till you find a good one, you may have to settle for one that is close to your monitors setup if the exact one isn't available.
If using a laptop with a standard screen with the wide monitor, you may need to disable the laptop screen and use just the monitor to get the correct resolution on the monitor.
Fran
Oct 13, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Images are too fat looking or spread out on my 22" monitor, how do i adjust so the images appear normal?
You need a video card that will adjust the resolution to the proper proportion. The closest I can get to a good aspect ratio is 1152 x 864.
Sep 28, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Distorted screen
Youre problem is because when a widescreen monitor is fed with a signal that is not ws it stretches the image sideways making people look short and fat. The only way to really fix this is to make sure the graphics card is providing a widescreen resolution to the monitor. In this case the native resolution (the resolution the screen looks best at) is 1680 x 1050 . If you right click ur desktop and go down to properties and settings u want to change the screen resolution to a widescreen res.
Hopefully 1680 x 1050 ... if this is unavailable try 1440 x 900
If you have an nvidia graphics card you can also go to the nvidia control panel and change the resolution attributes. If the widescreen res isnt available u could also try the 'change flat panel scaling' and select the do not scale option.
Please note before starting any of this make sure u have the latest graphics and monitor drivers available.
May 27, 2008 | Acer AL2016W 20" LCD Monitor
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
ViewSonic VA2026w Monitor Logo
69 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
