Question about FreeMotion 790 Interactive Treadmill
Freemotion 775 firmware update - FreeMotion 790 Interactive Treadmill
How do I purchase a manual for my FreeMotion 330R ??
First, try Googling (FreeMotion)(330R)(manual) without parens.
May 30, 2017 | FreeMotion Exercise & Fitness
Just got it and it will not power on. There is a red light on the circuit board inside of motor housing
http://www.sportsmith.net/images/product_support%5CFreeMotion%20Fitness%5Ctreadmills%5Cfmtl8505p2_freemotion_treadmill_owners_manual.pdf
Mar 30, 2015 | FreeMotion 775 Treadmill
Upgraded firmware on coolpix 775 to ver 1.4 but now camera will not read 8gb card used to do update even though reformated in camera
On page 153 of the manual, still on line here:
http://cdn-10.nikon-cdn.com/pdf/manuals/coolpix/CP775man.pdf
It says :
25461063-prrdqssrdmrazwwkxujz54sw-5-0.png So perhaps you could us a card up to 2 Gbyte, but more will be a problem. Even with new firmware it could be the camera can't address more then 2 Gbyte cards.
In the upgrade description (firmware is released in 2002 and the description last edited in 2007) it says you should use an in the manual approved memory card for the upgrade.
So special for the upgrade don't use a huge card. Only after the upgrade try other cards, but be aware the modern cards all could fail to work in this camera
Feb 21, 2015 | Nikon Coolpix 775 Digital Camera
Treadmill is receiving power but will not turn on
It sounds like you have verified power from the wall. I would also verify that the power cord is getting the power from the wall to the machine. If this tests good, continue to follow the power until it stops. By this I mean, make sure you are getting power past the on/off circuit breaker. If you are getting power past this and into the lower board, chances are the lower board is not sending power to upper board. This could be the cause of a faulty lower board or something as simple as a short in the wiring between the upper and lower board. You can check the wiring by using a multimeter to confirm continuity. The attached link is a quick guide on using a multimeter. Video about Multimeter Testing
Apr 12, 2014 | FreeMotion 775 Treadmill Exercise Machine
Machine not starting
Did you get power on the screen? Need more details of the problem.
Dec 30, 2013 | FreeMotion 775 Treadmill Exercise Machine
I have lost my power supply cord to my Freemotion 330R exercise bike. How can I get a replacement?
http://www.buyfitnessonline.com/cat alog/product
Pls order the cable from this site.
Oct 05, 2013 | FreeMotion 330R Exercise Bike
I need an owners manual for my freemotion tt30 terrain trainer treadmill
E-mail
customercare@freemotionfitness.com (I found it on the FreeMotion website). I needed one too, and they just send me a response with a pdf file of the manual. Hope that helps!
Nov 20, 2010 | Computers & Internet
My freemotion treadmill is slipping, what can I do?
ajusting the belt tension rollers, front and rear rollers tighten with usually a allen bolt ajustment tool
Oct 24, 2010 | FreeMotion Treadmill t7.3
How I can get software to overclock intel processor
if the BIOS does not have the configurations for it, you could try getting a BIOS firmware update, or buying a new BIOS from the company. otherwise it cannot be done.b
Jun 05, 2008 | Intel Motherboard
FreeMotion 790 Interactive Treadmill Logo
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
