Question about Kyocera Mita (km-c850d) All-In-One Printer
Need driver for Kyocera KM-C850D for win 98 - Kyocera Mita (km-c850d) All-In-One Printer
    Sergeant:
  • 138 Answers
Here is a website to download the driver for free:
http://nodevice.in/driver/download.html
Download this file by clicking save and save to your desktop, once on desktop right click and select "run in compatablity mode" and then hit the unblock button if it says blocked.
Posted on May 20, 2009
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Shawn
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
Kyocera will not print without kprint port
The KM-1650 will print useing a standard TCP/IP port printing over the network, I have done it ever since the machine came out. Load the print driver as a local printer and then setup a TCP/IP port and set the printer to print to that port in the printer properties.
Let me know if yo need more help.
Jan 15, 2010 | Kyocera Copystar Printing Systems -...
Kyocera cs-c4035e driver for mac 10.5.8 platform have older driver which works but won't give me color
You can copy and paste any of these links into your address bar to bring you to the driver download site:
www.nodevice.com/driver/KM-4035/get35425.html
driverscollection.com/?H=KM-4035&By=Kyocera...5
www.opendrivers.com/driver/.../kyocera-km-4035-twain-source-driver-v1.10.1-windows-os-free-download.html
Aug 24, 2009 | Office Equipment & Supplies
Duplex
check in the printer driver that in the device settings you have duplex enabled, otherwise you cannot use the duplex unit.
Oct 29, 2008 | Kyocera Mita KM-2530 Laser Printer
Paper Jam/Kyocera C850/C850D
There will be a piece of paper stuck in there follow the instructions again opening every door on the left side. If there is not some paper the likely thing is that the paper sensor is jammed open or the light reflector sensor is dirty or the last thing is one of the sensors are faulty.
But I know these machines very well and the sensors rarely go faulty so I'm 98% sure there will be just a small piece of paper stuck in there. (It may be between the two doors or stuck behind a guide.
Oct 18, 2007 | Kyocera Mita (km-c850d) All-In-One Printer
Please help me
C2550 = Drive Motor Problem.
Try to reset it first. Enter the numbers "10871087" on the keypad. Enter 906, press start, Press Execute on the touch panel. The machine will reboot.
If it comes back, you may have a bad drive motor.....or something else is dragging it down. Check that the developer unit turns. Check that the fuser unit turns. Check that all the gears in the transport unit turn. Maybe one has a bad tooth.
There is a double gear that sometimes causes the metal to flex on the transport unit frame and it doesn't mesh like it should.
Jul 29, 2007 | Kyocera Mita (km-c850d) All-In-One Printer
Kyocera Mita (km-c850d) All-In-One Printer Logo
49 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
