Question about Mattel UNO Blast Game
The wheel is not connecting properly to blast cards out
When the wheel is turning, it's not connecting to where it will make the cards fly out
1988 chevy pick up 5.7 some times when I turn the key it wont start I have to turn the fly wheel a inch or so for it to start any I dear what it might be
There are teeth on the fly wheel and you may have broken one or more teeth. You may have to replace the fly wheel. When you turn the fly wheel by hand you make the good teeth so the starter will work.
Jun 14, 2017 | Cars & Trucks
Wont start
battery terminal connections looseor corroded.Check the cable terminals at the battery.Tighten the cable and remove corrosion as necessary.Battery discharged or faulty.If the cable connections are clean and tight on the battery posts turn the key to the on position and switch on headlights and or windscreen wipers if they fail to function the battery is discharged.Automatic transmission not properly engaged in park or neutral or clutch pedal not completely depressed.Broken loose or disconnected wiring in the starting circuit, inspect all wiring in the starter solenoid and ignition switch.Starter motor pinion jammed in fly wheel ring gear, if manual place ransmission in gear and rock the vehicle to manually turn the engine.Remove the starter and inspect the pinion and fly wheel at earliest convenience.
Jun 07, 2013 | 1995 Jeep Grand Cherokee
How to put on the fly wheel 87 jeep comanche
the bolt holes should only allow you to install in one place
Jul 17, 2012 | 1987 Jeep Comanche
1994 dodge shadow es 3.0 v6 will not start. when I turn the key I can hear one single click then nothing. All lights work, replaced starter, checked battery terminals and wires for corrosion, fly whee
Replace the starter solenoid. Make sure you hook the wires back properly. Try jumping across the solenoid with cables to see the starter crank. That makes a direction to the starter. That's what the solenoid does. It connects those 2 cable ends together to make the starter crank over.
Nov 12, 2017 | 1994 Dodge Shadow
How do i change the starter on a 96 century
If it's the 3.1 or the newer 3100 the starter should just be a couple 13 and 15mm bolts. Plus the nut for the cable. Hope this helps.
Jul 13, 2009 | 1996 Buick Century
Car starts but sometimes makes a whirling noise. I was told it was the starter
sounds like the starter is not disengaging the fly wheel quickly like it should when you turn the key the starter cog connects upto a fly wheel that has teeth all around it when the teeth of starter cog connect between teen on wheel it spins it to crank your car then goes back to starter if you hold your key on after starting the noise you hear is the starter cog(teeth ) still engaged in wheel if this is the sound it needs to be serviced not neccassarily replaced
Jun 06, 2009 | 2003 Chevrolet Impala
94 safary grainded fly wheel
You more than likely need a new fly wheel, your fly wheel and starter are probably not making contact
Oct 18, 2008 | 1994 GMC Safari
Mattel UNO Blast Game Logo
135 people viewed this question
Top Mattel Games Experts
Pamela Leach
Pamela Leach
Camryn Johnson
Camryn Johnson
Level 1 Expert
Are you a Mattel Game Expert? Answer questions, earn points and help others
