Question about Protron PLTV-32 Television
PIP I'm having a problem trying to get my PIP to work,How do I change the Sub source from vga to av1 or av2. while in tv source mode, it wont allow me to change the sub source. can anyone help me, or give me a customer service # I can call. THANKS ' SMELL'
  • ENICKOLEDEE Apr 12, 2009
    TRYING TO GET MY PIP TO WORK
  • 4,102 Answers
Their should be an av button on controll might be button that says 0 if this dont work unplugg scart leads out the back switch it back on then when you put the scart lead back in it should pick up the signal and select the right mode for you hope this is some help it could be a problem with the telly itself maybe worth taking it to tv repair shop these will tell you for free what is wrong and how much to get put right sorry couldnt be any more help.............................
Posted on Oct 30, 2007
SOURCE:
Problem: TV Menu w Auto & Manual Scan greyed out cannot be selected
Check the input selected. if it is other than tuner, this might happen. Change the input to tuner, and check.
Jan 11, 2016 | Televison & Video
How do i get my nintendo wii console to appear on the tv screen ive tried every channel and hdmi and such and nothing i know its on and working cause i feel the wii remote vibrate just nothing shows o
Kate what did you plug the cables into I suspect it was a grey cable with a red , white and yellow plugs. If I am correct this cable should be plugged into the AV1 or AV2 input port of your television. Try changing the input source to AV1 or AV2 Check it is plugged to AV1 on the Television and not into Conponent input !
Jan 02, 2015 | Sceptre X32BV-Naga 32 in. LCD TV
Sanyo tv change to av1 av2
Whenever your change from one video source to another, your tv automatically switches input modes (i.e. av1 to av2) to faciliate the source coming into your tv.
Aug 10, 2014 | Sanyo DS32920 32" TV
The VCR won't record from a digital terminal.Connection Made according to instructions.Both VCR &digital terminal on channel 03.If the digital terminal is by-passed the recorder works fine.
use scart lead put one end into the digital ( BOX or TV ) out put ( AV1 or AV2) and the other into (AV1) on vcr then change the mode so AV1 shows on vcr display
you can do this by pressing button on remote marked with ( input / source or a picture with a arrow pointing into a tv
you can only record the station that the digital box or tv is on if you turn over vcr will record that station
Dec 16, 2009 | Hitachi VTFX6510A VCR
Lh300 sky box works with scart but wont work with hdmi cable just keeps saying no signal. new tv just received today
on your tv, have you selected the correct mode on your source button? eg, AV1, AV2 , PC, and HDMI
Oct 04, 2009 | LG 42LH30 42 in. LCD TV
Vizio VO32L & VO37L - PIP and Composite connection problems.
look in your owner's manual and you will see a list of input that can work with each other and ones that can't. If you don't have your service manual, you can go to vizio.com and get it there.
Jun 21, 2008 | Vizio L37 Television
Directed 9"Model OHD901: Power comes on, lights work, screen shows AV1 and AV2, dvd will not play at all
Preliminaries: (call Directed if these fail at 1-800-274-0200)
Make sure the disc format is supported - not HD, not Blu-Ray, and not an unfinalized burned disc
Make sure the lock switches are firmly in place
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off.
Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE)
Press the (SOURCE) button on the remote or momentarily press the POWER button on the left
side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting:
DISC does NOT Play
Parental code is set lower than than allowed by the DVD mounted.
Ensure the disk is mounted in the player with the correct orientation (shiny side up).
The disk is warped.
The player cannot play certain formats (see the beginning of this manual).
The region code on the DVD does not match the player.
Moisture condensation has occurred within the player. Leave the unit on and the disc access cover
open and try again after about 30 minutes.
The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came
with your disc authoring equipment.
May 23, 2008 | Televison & Video
PC connection
Hi, Im having similar problems my new laptop runs on vista and wont display on tc, also tv menu blanks out pc mode & PIP not displayed. Temporary qick fix is to set uo older laptop xp to tv wait for the desktop screen to appear the swith then cable from the old laptop to the new on - like a boost. doing that allows me to have the laptop display on my tv and allow me to access menu, PC & PIP
Feb 07, 2008 | Samsung HP-P5091 50 in. Plasma Television
PIP
Let me know what you find out, I have a similar problem. I can get the PIP screen to come up but it will not allow me to have it on an input that actually shows a picture - just blue screen.
junk@slaing.com
Dec 31, 2007 | Vizio L32 32 in. LCD HDTV
Protron PLTV-32 Television Logo
77 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
