Question about Lionel Greenberg's Repair Manual For Lionel Trains 1945-1969
Clean and repair GG1 lionel model locomotive - Lionel Greenberg's Repair Manual For Lionel Trains 1945-1969
5 Suggested Answers
SOURCE: Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Posted on Dec 23, 2009
jssummerfiel
SOURCE: I have a problem with
Had trouble with 072 switchs. Something is causing half the switch to loose track power. Most of the time it is the wide place on the switch. Had two of mind on both ends of the hot rail hookup do the same thing. What I did was have hot rail hookup in five or six different places. No problem now. Also have problems with derails at switch when going through ir backwards. Lional should in stall a small spring at the switch point to help hold it against the rail. No recommended but I took a punch and flatten the rail so it would push more on the switch point. OK so far. Hard to remove switchs when all your Fastrack is screw down.
Posted on Dec 17, 2012
residentoccu
  • 161 Answers
SOURCE: What is lionel smoke pellet tamper used for? Why needed?
Yes, you do just drop the pellet in...
But if there is any kind of crud built up in the
smoke stack, it may not allow the pellet
to seat on the heating element. Thus the
tamper is included to allow you to push
the pellet all the way down. If you don't
have one, a piece of wooden dowel the right
diameter can be used.
Posted on Jan 31, 2013
residentoccu
  • 161 Answers
SOURCE: Lionel battery operated g scale locomotive will not move
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Posted on Mar 02, 2013
The value of a train set 1953 Locomotive 1130
A Lionel 1130 is a "Scout" type locomotive....they are not particularly valuable even to collectors. They were a part of the low end starter sets Lionel made. Now if you had a similar vintage 736 Berkshire or a 681 or 682 Turbine they are worth considerably more.
Aug 10, 2016 | Crafts & Hobbies
Lionel f7 only runs in reverse
Have you checked to see if the direction switch is on? Most Lionel locomotives can be set to run in one direction by turning the direction sequencing off. This is true for the newer electronic direction circuits and the older electromechanical E-units. Sometimes the direction units fail and the locomotive will only go in one direction or sits in neutral. If that is the case, the direction unit will need to be serviced (mechanical type) or replaced (electronic type). Go to Lionel.com for additional information and help.
Mar 03, 2014 | Lionel Trains Santa Fe Flyer Freight Train...
Blinking green light
Check to make certain that the batteries in the remote are good. Make sure that when using the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If the train has been running successfully and the problem has only just started, clean your wheels and the pick up roller on the locomotive removing any fluff etc. then clean the track. If the loco is still not working contact the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
Jan 08, 2014 | Lionel (31956) Thomas The Train Set
Lionel train problems
Check to be sure that the reverse unit is on. This may be a lever on the top of the locomotive or a slide switch under the engine. If that doesn't solve the problem, you will need to take the engine to a service center to be repaired. A list of service centers can be found at Lionel.com
Dec 20, 2013 | Crafts & Hobbies
Help please. Lionel (30190) Thomas & Friends remote O gauge. Train won't move. Light comes no, nothing. I took the roof off and made sure the switch was in the on position. ??
First, check to make certain that the batteries in the remote are good.
Second, if the train has been running and the problem is new, clean your wheels and pick up roller on the locomotive, then clean the track.
Make certain that when you use the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If none of the above helps, contact the Lionel Service Department.
586-949-4100
Oct 07, 2013 | Lionel (31956) Thomas The Train Set
No smoke tryed every thing
Follow the link to the Lionel Service Document/Manual
http://www.lionel.com/media/servicedocuments/6299711323250LEGACYMallet.pdf
This link is for the customer Service Product Video:
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6371
Feb 16, 2013 | Lionel 628076 Nickel Plate Usra 2662...
Jan 19, 2013 | Lionel A Christmas Story Gauge Train Set...
Lionel train wheels are locking
1: clean & lubricate your engine2: if that does not work, the wheels may be out of quarter,check with Lionel Parts & Services.
http://www.lionel.com/ContactUs/
Dec 22, 2012 | Toys
I had the twin engine gg1 2360 repaired and the engines are running in opposite directions
it sounds like whoever did the repair reversed the pickup wires on one of the units.
Dec 20, 2012 | Lionel 18359 Pwc 2360 Gg-1 Engine and...
good luck
Dec 08, 2009 | Lionel The Polar Express Train Set
Lionel Greenberg's Repair Manual For Lionel Trains 1945-1969 Logo
32 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
