Question about Acer Aspire Computers & Internet
Acer aspire v5 blank screen error code oxc0000185
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 85 Answers
Alt + F10 is used to return the computer to the factory condition. If you do this you will lose everything which has been added to this computer since you first started it.
Can you boot into Safe Mode?
Safe Mode is found in the Advanced Boot Options, to access this start tapping the F8 key immediately after pressing the power button. If the Advanced Boot Options opens use the up or down key to move the cursor to Safe Mode and click on Enter
Posted on May 22, 2014
cgpatel1948
  • 258 Answers
SOURCE: how to get password from hdd password error code acer aspire 4315
Is the error message coming before bios starts to load XP from harddisk, or after?
If it is coming after XP starts then it may be driver issue.
If it is coming before XP, then it may be a question of incorrect bios for the hardware in your laptop.
Posted on Jul 29, 2008
SOURCE: my acer aspire 5535 screen keeps going blank
I had this problem. Laptop has been running for 24 hours and not a problem :-)
>Visit http://support.acer-euro.com/drivers/downloads.html
>Once on the website, select the Aspire 5535
>Then use the drop down and select "Bios Update for Vista" and select v1.04
>Once download is complete, extract to a temporary folder (eg create a folder in program files and extract there).
>Once this is down, go to the folder and open:
>ATI folder
>x86 folder
Ensure all other applications are closed.
>then run the CP2A_104 application.
Let this complete, the system then should reboot.
Once your back on, you should be good to go. This is a reminder, this may not work on all systems but it did on mine. You do this at your own risk and I accept no responsibility for any problems occured. If in doubt, refer to the Acer support line.
I wish you all the best as I know how much of a pain in the arse this problem is.
Posted on Dec 29, 2008
  • 67 Answers
SOURCE: acer aspire 3680 white screen
problably data-cable of LCD has contact problems or is broken. Consult someone with experience in opening the Display. DIY only if experienced, since you can make a $40 repair a $400 repair accidantly ... ;-)
Posted on Mar 31, 2009
cq92
  • 184 Answers
SOURCE: acer aspire 5310 the screen just blank and not
Possibly the monitor is defective - usually most laptops have a blue plug at the back for an external monitor, if plugging in a normal monitor brings up a screen, then likely the laptop monitor is defective. If you get a splash screen and bios info on trying to start it,it indicates your windows is defective or has lost it's start-up files - a windows reinstall will fix that.
Posted on Aug 29, 2009
joecoolvette
  • 5660 Answers
SOURCE: Acer Aspire Timeline AS3810T-8737 - No screen display. How can I fix?
http://www.newegg.com/Product/Product.aspx?Item=N82E16834115653
Let's diagnose, and see if the problem is the graphics chipset, on the motherboard, the video cable, or inside the Display Assembly itself.
[ Display Assembly is LCD Module for Acer.
LCD Module general description;
1) LCD Panel, (LCD screen),
2) LCD Bezel, (Plastic thin frame in front of LCD screen),
3) LCD Cover, (Top cover of laptop when it is closed, and over the LCD screen),
4) Camera, (Web camera)
5) LED backlighting,
6) LCD Panel Screen Frame
7) LCD Panel Brackets, (2)
8) Left Hinge, and Right Hinge
Orienting you with Acer nomenclature, as I will also be posting a Service Manual, in PDF file form, in a link.
LCD Panel Cable is Video Cable ]
A) Laptop OFF, monitor OFF, attach a VGA monitor to the laptop.
Goes to the VGA connector on the left rear side of the laptop.
This is a basic example of a VGA Cable, and VGA connector,
(On the laptop a VGA connector is known as a VGA port )
http://en.wikipedia.org/wiki/VGA_connector
For the external VGA monitor you can use a CRT type, (Looks like a small TV), or a flat LCD screen monitor, if it has a VGA cable.
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the external VGA monitor should have a display on it.
IF not;
There are at least three display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop, AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key. (Fn key is second key over from the left, on the bottom row)
At the SAME TIME tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
Still no? Hold the Fn key down again, and tap once more on the F5 key.
Still no? You have a bad graphics chipset. Usually means motherboard replacement.
{ Unless the graphics chipset is loose, in it's mounting on the motherboard. (Mounting = BGA surface mount)
If so the graphics chipset may be good, and it needs to be reflowed. The solder joints under the chipset need to be re-heated again, so the solder will reflow, and make good solder joints once more }
Good display on external VGA monitor?
Means the video cable is the problem, (LCD Panel Cable), or inside the Display Assembly. (LCD Module)
The video cable connects to the motherboard, under the Keyboard area to the upper left corner, routes up through the left Hinge, and into the Display Assembly, where it connects to the back/bottom of the LCD screen.
Just through normal opening, and closing of the laptop through the years, the video cable's sheath may become pinched, (Left Hinge), and pulled on when the laptop is opened.
Or worn against. Means if the sheath of the cable is pinched, and pulled on, so may the tiny little wires inside the sheath of the video cable. Stretched/Broken.
You have to disassemble the laptop far enough, so that you can remove the video cable, (LCD Panel Cable), and visually inspect it.
ANY signs of damage may mean damage to the tiny wires inside.
Even if no outward visual signs of damage are apparent, it would behoove you to have the video cable checked out.
Have a shop check the wires inside the video cable for continuity.
Make sure there are no breaks in the wires.
It could also just be a loose connection. Connection is loose on the motherboard side, or LCD Panel connection.
It is pretty apparent if the connection is loose on the motherboard side. Just needs to be plugged in tight. When it is plugged in tightly, it looks it.
It is not so apparent on the LCD Panel side. (LCD screen)
Connector is VERY small for one thing. It also doesn't take very much of a loose connection, at the connector. Hard to see. Best method, is to just to physically make sure the video cable is plugged in tightly, to the connector on the LCD screen. (LCD Panel)
Video cable is in good repair, and there were no loose connections?
(You can use the laptop to see, before you put everything back together)
Then the problem is the LCD screen. (LCD Panel)
It uses a series of LED's as a Backlight. They are built into the LCD screen.
There is NO screen Inverter. The LED backlighting does not require a screen Inverter.
Therefore the only method is to just replace the LCD screen.
http://www.screencountry.com/index.php?section=products&model=ASPIRE%203810T-8737%20TIMELINE&brand=Acer&size=
Just an example, no advertising. You may find a better price, from a reputable dealer also.
More information;
Pictorial guide to replacing an LCD Panel, for an Acer Aspire Timeline 3810T Notebook PC,
http://www.insidemylaptop.com/replace-broken-screen-acer-aspire-3810t-laptop/
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Suggest you buy, and use an ESD wrist strap. Average cost is around $3 to $6. Connect it's alligator clip to a good ground source.
One example,
http://www.radioshack.com/product/index.jsp?productId=2103245
[ I connect to an unpainted surface, of the metal frame of an open, empty desktop computer.
You can also set a large metal serving tray on your work table, and connect to it. (Unpainted)
Or a large metal knickknack. (Unpainted ]
Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws. Advise DO NOT mix them up.
A) In Step 1.
The Screw Covers are made of a synthetic rubber. They have a type of rubber cement on the bottom of them, that holds them to the screw head.
I use a computer pick to remove them. You may have a similar tool, or substitute with your choice.
Just ease up on one bottom edge, and pick up. If you store the screw covers correctly, and remove properly, you can more than likely reuse them again. I just lightly stick them on the LCD Bezel.
(The thin plastic frame in front of the LCD screen)
Then remove all the Philips head screws. The LCD Bezel pops off.
It has locking tabs on the outside edges. The inside edge of the Display Cover has matching locking latches.
Just go to the inside edge of the LCD Bezel, as shown in Step 2, and ease it away from the LCD screen. It flexes. When the top/middle of the bezel is flexed away from the LCD screen, a little, ease a finger under it, and go to one side. Now go to the other side.
Once you start working down one of the sides, the bezel should start to pop off.
[IF you are keeping the LCD screen, and not replacing it, WATCH your fingernails! They will scratch the LCD screen.
Use computer gloves, and/or protect the LCD screen with a thick piece of construction paper. I cut a thick piece of construction paper to fit the inner opening of the LCD Bezel ]
B) You have to remove the Keyboard to remove the Upper Cover. You have to remove the Upper Cover, to access the video cable's motherboard connector.
The Keyboard Cable stays attached to the Keyboard. It removes from the motherboard connector.
The Keyboard Cable is a FFC. Flat Flex Cable. It has NO connector on the end.
The motherboard connector that the Keyboard Cable attaches to, is a ZIF connector. Zero Insertion Force.
It is made of two pieces, but DOES NOT come completely apart, in order to remove the Keyboard Cable.
There is a larger rectangular piece on the bottom. This is the BODY.
There is a smaller rectangular piece that goes across the top. This is the LOCKING BAR.
The Locking Bar moves away from the Body. Slid up towards the LCD screen.
It ONLY moves about 1mm to 2mm. That is a little larger than 1/32nd of an Inch, to 1/16th of an Inch.
IF, the Locking Bar comes off of the Body, it is broken.
If it is broken you are looking at -> motherboard replacement.
This is why I am being so detailed.
Pictorial guide using an Acer Aspire 4810TZG,
http://www.insidemylaptop.com/disassemble-aspire-4810t-4810tz-4810tzg-4410-laptop/
In Step 16 you see the two brown tabs, of the brown Locking Bar.
One on the Left, one on the Right. These little tabs are all you see.
In Step 17 you see the Locking Bar moved up away, from the Body.
Now the FFC (Keyboard Cable) can be gently pulled out.
NOTE the direction it is installed. HAS to go back in the same direction. Twisted Keyboard Cable, or not.
[Flat contact pins in Keyboard Cable, MUST realign with the SAME contacts, in the motherboard's connector, as it was originally installed from the factory ]
Steps 12 through 14 show you more on removing the Keyboard.
The latches you need to depress, where they are, and how it's done.
Also shows rolling the Keyboard over, so that the Keyboard Cable can be disconnected. (Have to disconnect cable before you can remove the Keyboard, 'natch )
Also watch lifting the Keyboard straight up. There are tabs on the side if the Keyboard towards you, and they can be broken off. Lift the Keyboard at an angle, gently move towards the LCD screen, then lift straight up, and roll over on the Upper Cover.
Link to free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
On this page drop down to the 'paragraph' that starts with Aspire 1200. (1200 in blue)
Go down to the 4th line, and left-click on -> 3810T
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (3810T) it may take up to 30 seconds, before the first page comes up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jul 04, 2012
HOW DO I FIX ACER ASPIRE V5-571
Insert your system disc, boot from it and run rescue.
Aug 18, 2015 | Acer Computers & Internet
My Acer Aspire V5-571 does not load up it shows acer screen when turning on the laptop then loading floating ball comes on screen for a few seconds then black screen ? can any one please help ?
Hi Jim,
this seems like a no boot / no video kind off issue and mostly is coz of corruptions in softwares or drivers, try booting the computer in safe mode. if it does, then take a data backup. i would not recommend experimenting in this issue as it can crash the computer.
hence call 1-877-805-1027 for expert help.
Aug 18, 2015 | Acer Aspire V5 571-6614 : 1.6GHz Core i5 ,...
How do I fix / replace a cracked screen on Acer Aspire V5 - 571 LAPTOP
Take a look on Amazon for the screen and then google the term "disassemble Acer Aspire V5-571P. There are most likely videos showing how to do this.
May 16, 2015 | Acer Computers & Internet
My acer aspire v5-122P-0408 has a blank screen what do i do
Disconnect the power cord and remove the battery!
Reinstall battery and connect the power and see what happens!
Jan 05, 2015 | Acer Aspire V5-122p-0408 11.6" Touchscreen...
My acer v5 has a blank sceen
There is hardware issue, if you have a little bit knowledge of computer hardware and have a tool to open it , then trun the laptop and open the screw of ram portion to clean the ram. if this will not work for you then please consult with it expert chipset level computer engineer.
Sep 22, 2014 | Acer Aspire V5
How do I fix an error code Oxc0000185 ?
Dial our HP Customer Support Phone Number 1-844-355-5111 for HP Customer Service to fix an error code Oxc0000185. Here with HP Customer Support you will get exclusive HP help,offered by well-trained technicians.
HP Customer Support Phone Number 1 844 355 5111 HP Help
1-844-355-5111 hp customer support phone number-r3jwe4py31xoj0ee0gunh0fe-5-0.jpg
Jul 29, 2014 | Dell Inspiron 13z 5323 Core i5-3317U...
Acer aspire v7 won't turn on
I assume this is running win 8/8.1 then it could be that it needs resetting to defaults, your best option is to contact tech support to find out how to reset the unit.
Jul 12, 2014 | Acer Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
