Question about Toshiba Satellite A105 Notebook
Do not know bios password for toshiba portege r400
PAeasop
  • 17 Answers
SOURCE: Toshiba Portege S100 Bios password
Nedacqua,
The only way to obtain the response for the challenge code is to send your unit to an authorized repair facility. I work at the depot repair facility in Lou.Ky. And we have to send a request to Japan or California to get the response code.
PAeasop
Posted on Apr 25, 2008
gurutim
  • 68 Answers
SOURCE: how to reset the power on password toshiba portege r100
Go to: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?ct=SB&soid=108503&ref=EV
Drill down to your password reset scenario. This is for all Toshiba laptops.
If this helps you, and you wouldn't mind, please take the time to rate my response to you.
Much appreciated...
gurutim
Posted on Mar 22, 2009
micromaster
  • 3614 Answers
SOURCE: Toshiba Portege R200 laptop service manual
If you can't find the jumper to flash the BIOS or if such jumper doesn't exist, you can remove the battery that keeps the BIOS memory alive. It's a button-size battery somewhere on the motherboard (on elder computers the battery could be a small, typically blue, cylinder soldered to the motherboard, but usually has a jumper on its side to disconnect it, otherwise you'll have to unsolder it and then solder it back). Take it away for 15-30 minutes or more, then put it back and the data contained into the BIOS memory should be volatilized. I'd suggest you to remove it for about one hour to be sure, because if you put it back when the data aren't erased yet you'll have to wait more time, as you've never removed it. If at first it doesn't work, try to remove the battery overnight.
Important note: in laptop and notebooks you don't have to remove the computer's power batteries (which would be useless), but you should open your computer and remove the CMOS battery from the motherboard.
Posted on May 30, 2009
  • 220 Answers
SOURCE: Bios password toshiba portege 3440ct
findout where you cmos battery is,either under battery or keyboard,remove battery,turn on/off.install battery,will prompt to enter date and time.
Posted on Jun 29, 2009
SOURCE: password bios toshiba
as such way of vanishing password bios toshiba m500
pleace in sending via enamel : sgt_wiwi@yahoo.co.id
Posted on Jul 16, 2009
How to reset bios password on toshiba portege m200 2001
Open CPU Cabinet's case and look for button cell of coin size on the main motherboard(circuit board) and push the pin with holding the button cell, the cell will come out. This will power off the BIOS memory and the BIOS will reset.
Oct 18, 2012 | Toshiba Computers & Internet
How to reset the boot password in toshiba portege a100 laptop
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Mar 08, 2010 | Toshiba Portege S100-S1133 Notebook
Bios password toshiba portege 3440ct. I can't find a solution, my bios is locked and I don't know a password.What can I do, Is anybody help me thanks............
Jun 27, 2009 | Toshiba Portege 3440CT Notebook
Don't know how to get rid of hard drive password on toshiba lapto
A hard drive password can only be removed by the person who knows the password because then it can be cleared thru the BIOS.
Otherwise the only other way around it is the buy a new hard drive so it doesn't have a password and you can then reinstall the operating system on the hard drive and then put the drivers on it and any other programs that you want on it.
Apr 07, 2009 | Toshiba Portege M200 Tablet PC
Password bios toshiba portege r500
Mar 29, 2009 | Toshiba Portege S100-S1133 Notebook
Toshiba Portege 3500 Win Xp Bios password - How Can I flash bios?
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.
After that use the patch
Mar 08, 2009 | Toshiba Portege 3500 Tablet PC
Bios password for toshiba laptop needs reset
Try This: Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
Older Toshiba laptopsmag-glass_10x10.gif can be convinced to boot without their power-on BIOS password by attaching a dongle to the parallel port which crosses a number of the pins. The pin out is:
Pins 1-5-10 2-11 3-17 4-12 6-16 7-13 8-14 9-15 Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Feb 14, 2009 | Toshiba Portege S100-S1133 Notebook
Toshiba portege R100 bloqu? sur password
Hello:
i have problem portege ,when i do on it, always password show,but i have not not any
before password, any one knows how reset the bios ,
my e-mail: selectpro@hotmail.fr
May 22, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A105 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
