Question about Sony Cyber-shot DSC-W50 Digital Camera
This soluction not working
Receive "access" error when I turn on my camera. The lens continually tries to open and close. This repeats until I get a message: to power off and restart again. I tried that many times with no success. I change my battery with no success. I changed my memory stick also without any success.
I have tried to do a reset, however I cannot get access to any function keys to begin the reset function
    Problem Solver:
  • 5 Answers
I`m afraid resetting the camera will not work. The camera has a lens problem and is therefore giving the error.
Contacting your nearest Sony service centre is your only solution.
Sorry about the bad news : (
Posted on Nov 04, 2007
I started taking pics on my daughter's birthday function.. at the end of the function, my friend tried to take the camera from me but unforturnately it fell down. But we continued take pics and but after...
Try repeatly turning on and off the unit by removing the battery each time the lens error screen pops up...that worked for me this summer when mine S210 got jammed with a sand particle. The next level is to get access to the front cover. That requires more knowledgethan I'm currently aware of as I've only removed the back cover and the LCD retainer plate. Tomorrow I'm going after the front cover and I'll let you know if I'm successful. The entire camera seems to be accessible with a small phillips head screwdriver and a lot of patience. Taking apart an S210 requires great peace of mind...don't go in until you're in a good space...
Sep 27, 2010 | Nikon Coolpix S210 Digital Camera
Turn on but not working
Most all cameras have a "FORMAT" mode that is accessable through your MENU options. Find It and try RE FORMATING YOUR CAMERA. You may lose stored images but it will reset the Camera back to Factory settings. Good Luck
Oct 09, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Access Probelm with DSC-W50 camera
abrakati,i have the same problem,still unsolved.however,to access the menu i depressed the button to view 'shots' taken.while in that mode i was able to access the menu but resetting did ****.i still get the same malfunction.chris.
May 27, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
I receive ''access'' error
The "Access" will stay there until your camera passes it's self lens test. The test runs 3 times, then gives up with an error message. The cause of this problem is most likely a grain of sand somewhere in the lens. Only a camera tech could possibly ever hope to find it. Replace the camera lens.
Nov 12, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Dsc w7
While turning in off softely press the lense in and out a couple of times. The lense would retract. If not fully, but most of the way, push the lense a little harder in until completely retract. If you turn it on, I should work fine. The reason the lense does not retract is most likely some dust in there somewhere. If it did not help, you would have to open the lense and clean it and close the lense.
I hope it helps,
Jul 13, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
well well well a simple way to fix it if u r scraed to whack thn tap the lens,menu part ,sides wid a pensil or a pen...bit little harder atlest d cam should get little vibrations well it really works...belive even i had d same problem just after 15days just d previos day to a holiday...thn i just tapped itwid ma fingure n u wont belive it worked...
Feb 12, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
The soluction not working
Tap side of camera with base of hand with 2 or 3 sharp taps.  Then turn camera on.  Problem should be solved.
Oct 18, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Lens Stuck
Same problem guys!!! LENS HAD GOT STUCK - ABOUT ONE THIRD OUT after a knock. After lots of playing, and tapping and batteries in and out tried the whole twisting and pulling thing whilst turning off and on.
After a few minutes it came free and whole lens popped out. I then had to twist the outer part of the lens to straighten that up and allow it to fully retract. Works a treat now!
PS Tried the Sony online chat support - useless!!!!
Sep 08, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Access problem with DSC-W50
It's a problem with the lens. Usually, the internal focus lens jams up, or is out of alignment. It has to be opened up to be fixed, and the lens might have to be replaced. Occasionally, you can give the camera a good whack in your hand while it's powering up. Just be very careful not to hit the lens, or the LCD; as they can be permanantly damaged. Hit it with your palm on the corner, or edge. Also be sure the camera doesn't fly out of your hand...then it, or something will break, obviously.
Sep 06, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-Shot (DSC-W50) Access Problem
did you try to reset the camera or call sony?
Aug 31, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
74 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
