Question about Maytag Washing Machines
My washer is leaking from the bottom
It seems to only happen when i have a super load or set to that function.
  • 47 Answers
REPLACE THE HOSE OR CALL THE REPAIRMAN.
RODNEY
Posted on May 20, 2009
Washing machine
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Aug 04, 2008 | GE WJSR2070B Top Load Washer
My GE Washing machine appears to be leaking from the bottom
It sounds to me , you need the seal and bearing kit.. It is over 300.00 dollar repair, if it is an old washer I would say go get a new one
Jan 13, 2010 | GE Profile Performance WPSF4170WAA
Leaking from the bottom from GE super capacity plus washer maching
Take the front off and if it is leaking from where the transmission meets the tub the tub seal is bad. When this happens you have to replace the seal and the transmissson. This page can help http://appliance-repair-it.com/GE-washer-disassembly.html
Jan 02, 2010 | GE WBSR3140DW Top Load Washer
I just did a load of laundry at my mom's beach house. Second load so far is fine, however, first load seemed to leek from underneath. All water/drainage connections were dry. We moved and cleaned area and...
If all connections were dry, the water may have overflowed the top of the tub during a spin /rinse cycle. That could happen if there was a lot of water (i.e. set for large load) and a small amount of clothes.
Jul 08, 2009 | Washing Machines
Leaks occur in spin/empty cycle
I had the same problem, you need to turn the washing machine on it's side and look for a pin hole leak in the seam of the plastic holding drum on the bottom. I used a silicone sealant, "GOOP" , let it dry for 1 day and problem solved. It has not leaked in two years. good luck!
Nov 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool heavy duty super capacity plus
What is the model number of your washer if it is a Duet then First you need to unplug the washer and then remove the front cover below the loading door... (Should be 3 Phillips screws on the very bottom).The top cover comes of just as easy the 3 Phillips screws are on the top back side of the machine.....If its not a Duet please give me the model number and I'll see what I can find for ya…. Please give me feed back
cbinny1
Oct 19, 2008 | Washing Machines
Water leaking out the bottom of door
You are using too much detergent. Make certain you use HE (high efficiency) detergent, and one of the service technicians suggests only using about one tablespoon of detergent per load.
Oct 18, 2008 | LG WM2277H Front Load Washer
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
Oct 09, 2008 | GE WBSE2090A Top Load Washer
Water leaking when when washer is running a large or super load
the leak could be coming from anywhere in the washer it just leaks out from the lowest point of the washer i would suggest placing a putty knife under the top on the right and left side and pushing the tabs in to pop off the front panel to see where the leak is coming from
Oct 30, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
