Question about HP LaserJet 4650dn Printer
49.4401 service error on start up
49.4401 service error comes up on start up
  • ccolley May 20, 2009
    I have tried that and after I hit the check button it nevers stops displaying the hp logo and never finishes intialization.
    no - not sure how when it will boot up
  • HP Master
  • 4,338 Answers
Solution or Workaround:
1) TRY to flash the firmware.
2) Try cold reset and disk initializations.
3) Replace firmware dimm.
If you have a hard disk:
To resolve the issue it may be necessary to perform the Disk Init procedure.
Disk Init Procedure
1. Turn the printer off, then on
2. When the memory count starts on the control Panel, press and hold the Menu button until all 3 lights on the control panel are lid
3. Press the < button. The message “INITIALIZE DISK” appears in the display
4. Press the Check button. The printer will initialize the User space on the Compact flash and will continue it’s power-on sequence.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 20, 2009
  • JDTec
    JDTec May 20, 2009
    Have you updated the Firmware?
  • JDTec
    JDTec May 20, 2009
    Firmware update is your best bet right now.
Yes i solved the Printer 4650 error code 49.4401
Disk Init Procedure
3. Press the < button. The message "INITIALIZE DISK" appears in the display
4. Press the Check button. The printer will initialize the User space on the Compact flash and will continue it's power-on sequence
Tanveer aslam
Styluscomuters
pakistan
Posted on Aug 06, 2011
5 Suggested Answers
  • 300 Answers
SOURCE: 49.FF05 SERVICE ERROR
A critical firmware error has
occurred.
Try following these steps -
1. Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off, and then
turn the printer on again.
3. Go to http: www.hp.com/
support/lj2410, www.hp.com/
support/lj2420, or
www.hp.com/support/lj2430.
Click Download Drivers and
Software
. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware
upgrades.
4. Try printing a job from a
different software program. If
the job prints, go back to the
first program and try printing a
different file. If the message
appears only with a certain
software program or print job,
contact the software vendor
for assistance.
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
all cables that connect the
printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
4. Remove all of the
EIO devices from the printer.
5. Turn the printer on.
6. If the error message
disappears, reinstall
each DIMM and EIO device
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
replace the firmware DIMM.
10. Replace the formatter
Posted on Jul 14, 2008
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
  • 9 Answers
SOURCE: HP LaserJet 4345mfp won't scan, but it wil fax.
This may be related to 3 problems . 1st as with all 49.xxx errors update your firmware first. 2nd it may be related to a memory problem internal to the printer. Last it may be a problem with the email server you are sending to. To troubleshoot update firmware, then remove network cable and try to scan docs is as if you were going to email. If problem does not show check email gate way. If problem does shw up replacing your memory may be the next step.
Posted on Nov 11, 2009
  • 82 Answers
SOURCE: 49.ff95 service error
You need to get a technician in. The code is suggesting the formatter board.
Note that make sure that the technician (or you if you are replacing it) that once you replace the board and turn on the machine, don't do anything for about 10 minutes. No printing, nothing. Take out the network/usb cord out to prevent anyone from printing. The reason is that the NVRAM (memory) is updating the new board with your information. If anyone prints (whether from a computer or a configuration page) then it will interrupt the update and you will get the same error again.
Posted on Dec 08, 2009
Error code GARO W1234 keeps coming up why
1. unplug data cable
2. go to service mode
Aug 26, 2015 | Canon imagePROGRAF iPF8000 Printer
Noise coming from front end and ABS/Stabilitrak errors
sounds like your abs ring on the axle has come loose
Dec 04, 2012 | 2009 GMC Sierra 1500
Laars LX 250 AGS Service error. Burners ignite the go out.
if connected 120 volt switch red and black wires its not rectification
Nov 17, 2012 | Jandy Laars Lt 250,000 Btu Heater
C:\PROGRA~1\MYWEBS ~1\bar\2.bin\m3plugin.dll This error comes up everytime I start my laptop, I've looked at some solutions and it comes from MY Web Search, but when I try to uninstall the prog,
Go to Start - Run and type MSCONFIG then press Enter and choose either Services or Startup to try to identify which application may be loading m3plugin.dll and uncheck it
Apr 10, 2012 | Microsoft Windows Vista Ultimate Edition
What does it mean when i get the error message print spooler services not running
you need to turn it on, Go, . START>>RUN>>services.msc enter. When the services screen comes up, scroll down until you find the "Print Spooler" Enable it, Start it, and set to Automatic, reboot, ya good to go.
Mar 15, 2010 | Brother HL 2140 Laser Printer
Epson 3800 won't work
you cant fix it of your own better to visit service centre.
this error require counter reset through software
Jun 10, 2009 | Epson Stylus Pro 3800 InkJet Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
HI,
right click on my computer -> select manage -> one should be services and something (or something like that) open that and go to services -> find the printer spool service and right click on it -> click on properties -> in the printer spool service properites click the "Start" button and also under a drop down menu change it from "Disabled" to "Automatic".... This is what you did right ?
Log in to Administrator account and try it there. If that doesn't work then install a fresh copy of Windows Xp. It should work now. Thank you.
Sep 07, 2008 | Office Equipment & Supplies
Error: avgmfx86.sys starting service, error 0x8007007f
Error code 0x8007007f or error code 0x8007007e loadTOCNode(2, 'cause');This problem frequently occurs after you upgrade a service pack. After you upgrade, there appears to be a corrupted file, a missing file, or a file mismatch
That is what microsoft's website says about the error. Have you tried uninstalling and reinstalling? Also have you made sure you have all the microsoft updates available installed.
Keep me posted,
Lee
Jun 16, 2008 | Edirol UA-4FX External Sound System
HP LaserJet 4650dn Printer Logo
2,131 people viewed this question
Seeker5211
Seeker5211
