Question about Dryers
Check lint screen light is on. Dryer won't start.
  • 1 more comment
  • rick817 May 20, 2009
    I was not able to find the site that shows the picture description of the fuse location near the blower box.
    Hi, I might not have given enough information the first time. I have a Kenmore Elite Dryer. 'Check Lint Screen' light is flashing and dryer will not start. All lights are on. I have cleaned the lint traps and checked the vent tubes.
    Rick
    Yes, I was able to verify it was the Thermal Fuse by going around it for a test. The diagrams were very helpful in locating the fuse.
    Rick
    Novelist:
  • 151 Answers
Http://www.applianceaid.com/pictools/thermalfuse&stat.JPG
click this link directly this is the direct link to thermal fuse. If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first, then it is sometimes a good idea to replace the operating thermostat at the same time. This is a picture of -some- modern thermal fuses.
If your dryer doesn't work it all and only check lint light is blinking then , check these:
Power from the house
Door switch
Timer
Thermal fuse
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Timer If there are open contacts in the timer, it won't operate.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on May 20, 2009
    Genius:
  • 1,689 Answers
Hi Rick
A melting type fuse mounts on the blower housing and is tied into thesame circuit as the door switch. When it melts it shuts down everythingand this keeps the lint from catching fire.
usually it looks like this : http://forum.appliancepartspros.com/attachments/dryer-repair/761d1231776071-dryer-lint-screen-light-wont-work-fuse-2.jpg
To resolve the issue, just get a replacement fuse, remove the melted one and then put the new one in place.
here are also some tips in cleaning your dryer.
http://www.laundry-alternative.com/clean_dryer_vent.htm
http://www.doityourself.com/stry/stainindryer
hope this helps.
regards,
voodoo
Error code CL on Kenmore Dryer
The "Check lint screen" light is just a reminder to check the and clean the lint screen before or after each load. There is not a sensor that will detect if it's clean or dirty, it's just a reminder. The "Check lint screen" should turn off as soon as the dryer is started. If it never turns off then the control board would need to be replaced in order for the check lint screen reminder to turn off, however the check ling screen reminder light staying on will not effect the operation of the dryer.
Here is the control board to order.
The part comes with a 365 day, any part, any reason return.
Nov 02, 2012 | Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Lint filter light goes on; vent unattached so no blockage and lint screen is clean. Thermostat? Temperature regulator? Model 3510 - about 6 plus years old
Hi
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes, I mean if you have not done this already. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the Thermal fuse that has gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 15, 2010 | Bosch Axxis WTA 3510 Electric Dryer
My check lint filter light is on, lint filter has been cleaned. is the exhaust line possible clogged? I have a Epix Z series dryer, the lint filter was not cleaned and now the check lint fileter light is...
Hi
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the sensor that has gone bad and needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2010 | Maytag EPICz 6.7 Cu. Ft. King-Size...
Sears HE3 Dryer - "Check Lint Screen" light is on. I cleaned lint screen and area around screen but light will not extinguish and dryer will not turn on. I unplugged dryer for a time and plugged back in...
I am not familiar with your dryer, but it sounds like a safety mechanism where if your lint screen is not cleaned the dryer will not turn on. That "Check Lint Screen" light for your dryer may be connected to a sensor near the lint screen area. Check that out and see if that is the problem. If there is a sensor it could be faulty,
Apr 28, 2010 | Dryers
PF indication (Power Failure) and dryer digital light up but will not start
check your owners manual for clearing error codes in trouble shooting on theese electronic models lots of time you have to clear the codes to go back to normal ops by pushing certian buttons on kenmore i dont know which ones they are usaly its clear/cancel buttion some times you have to holld them so many seconds just unplugging it will make it think it has another power failure
Dec 26, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
93 people viewed this question
Top Dryers Experts
