Question about Palm Treo 650 Handheld
Phone Dying I replaced the battery and it started to work again, then is began to die, again. Now it won't start at all. Every few times i re-load the battery, it will start to show the start screen loading, then slowly die again, to nothing. Is there a way to re-wire the software? What has "died" that isn't working?
    Problem Solver:
  • 11 Answers
Sounds like the power connector problem again look at the other threads here and see if your phone is doing the same.
Kevan
Posted on Nov 18, 2007
Our 1992 Chevy caprice keeps dying while driving and won't start again. only once did jump starting it work. The next i time we tried to jump it it wouldn't start but the folowing morning it started up on...
More probably the fuel pump, which is overheating after driving a while and stops working (bad bearings or vapor lock). When it cools off, it may work again for a while until it overheats again.
Jul 15, 2017 | Chevrolet Caprice Cars & Trucks
My car began not starting right away and then finally would,now won't start at all. Died a couple of times while driving
Could be the cranking amps in the battery are under par. Needing new battery. Or the alternater is not working properly.
Dec 11, 2011 | 2001 Chevrolet Cavalier
2001 Galant car dies among other things
the issues with testing an alternator, is that if it is a turbine error, that never starts until constant wear is being promoted by the computer.
This "Mechanic" was he using an OBD Scanner? if not? why Not?
have someone do a diagnostics on your car.
Aug 26, 2009 | 2001 Mitsubishi Galant
Battery
Usually, if the battery is dying, it won't start up again.
Usually, motorized vehicles only use the battery to start the engine, then the alternator contributes all the power for actual operation.
A dead alternator or battery shouldn't 'sputter', they would just stop dead.
If the engine will start, run and then sputter...there is a fuel problem.
1. There may be a 'cut-off' in the fuel line which is in the off postion. It may look like a thin, flat wing-nut.
2. The gas may be contaminated with water residue if the gasoline has been sitting a long time. I believe you can get some water treatment to fix this without having to dump the fuel tank contents.
3. The fuel line is blocked with dirt somewhere, I would check the fuel filter and work backwards from there.
Jul 07, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
05 ford escape wont start. jump started it and it started fine but only runned for a few minutes and the engine started to stall and went off. tried to start it again and it wont turn with the same...
okay try this....talk to your parts store and get a battery load tester, and find out if the battery is indeed dead. My guess is it sounds like the Altenator is dying. they are around 50-100 and can be install by a pro in minutes.
Jun 16, 2009 | 2005 Ford Escape
Replacing battery and car dying out
something else is wrong with the car now,. the battery took care of the starting problem but you may want to have the alternator looked at as well. but what its doing now is a separate issue
Dec 28, 2008 | 2003 Mitsubishi Lancer
Car dies and battery light comes on.
Will it crank over when it won't start? When It dies check for spark at the sparkplugs if none change the ignition module.
http://www.aceautomotive1.com FaQ and BLOG
Aug 01, 2008 | 1999 Chevrolet Cavalier
Engine keeps dying
Time to switch to a low consumption car my friend
You are financing Terrorist countries such as Syria and Iran!
Jul 14, 2008 | 1998 Nissan Frontier
Palm Treo 650 Handheld Logo
76 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
