Question about Stanley Garden
How do I know when my stanley bar flex light is charge
3 Suggested Answers
SOURCE: need to change the batteries
Sorry, the batteries on this light are permanently installed and are not replaceable.
You charge it like a cell phone with a wall charger.
When it no longer takes a charge, throw it away. Not a real great product.
Regards,
The Electron Guru
Posted on Aug 19, 2011
gerardrjj
  • 6 Answers
I know this thread is old, but I just had to change the battery pack in mine. I could not locate a 4 pin battery pack so here's what I did:
You'll need: 3 NiMH 1.2v AA solder tab batteries, Razor blade, #1 Phillips driver, Kapton tap (standard electrical tape will do), soldering gun/iron, spare 18awg wire
1. Use a razor blade to remove the black sticker from the bottom of the flashlight base, it covers the magnets
2. remove the three outer phillips screws (the inner ones hold the magnets in and can stay installed)
3. Pull off the bottom plate
4. Pull out the battery pack and disconnect it from the flashlight at the 4-pin queeze connector
5. Remove the outer wrap and end protectors from the old pack keeping the end protectors in tact
6. Assemble the 3 new batteries in the same configuration as the old pack using Kapton tape, connecting + to - at the same two spots (use the old pack as a reference)
7. Carefully desolder the 2 wire leads from the old battery pack
8. connect up the 2 power wires to the same two spots as the old pack and insert the temperature probe between two of the batteries as in the old pack
9. Put the end caps on the new pack and wrap the entire thing in Kapton tape to simulate the plastic wrapper you removed
10. Install pack in to base, secure bottom plate and re-adhere black sticker(if needed you can use non-foam double-sided tape or spray adhesive)
The old pack was rated at 1300mAh and I used three 2000mAh each for a total of 6000mAh so theoretically the light should run for about 6 times as long between charges.
Posted on Apr 03, 2014
I am looking for a Stanley Model SL2M09L - Want to know how long a battery using ac power will take to charge. Thank You
Hello, Joseph -
I hope I am safe in assuming you are asking about a Stanley cordless rechargeable spotlight. If so, according to the owner's manual I found through the Stanley tools home page:
(Link to the owner's manual):
https://docs.wixstatic.com/ugd/217982_ae7e48e26fee4748ab08acf8435c8efc.pdf
on Pages 4-5 of the manual, starting at the bottom of Page 4 and continuing on the top of Page 5, it states:
Therefore, depending upon the charging source the recharging will take between 5 to 20 hours.
Note: Your question landed in the category of Computers & Internet.
Jan 05, 2018 | Power Computers & Internet
How do I get my Stanley 2m series spotlight to Charge?
To take the charge the inbuilt battery must be functional. Once the battery goes bad you will be unable to charge the unit or it will take a small charge and die rapidly thereafter.
You may or may not be able to change the battery. It depends on the manufacturer of the product so you should consult the instructions that came with the item if you still have them.
Nov 28, 2015 | Stanley Camping, Backpacking & Hiking
How to charge jump starter
If the battery is real low, It takes about 8 hours to recharge it,
Dec 05, 2012 | Stanley Black & Decker Stanley J5c09 500...
My stanley 300 amp jump-start system lights flickering when I plug it in to charge?
Apr 20, 2012 | Stanley 300 Amp w/12V USB Jump Starter -...
How long do i have to charge the stanley j309 300 amp battery booster
Before the first use, the unit must be charged for 24 hours with a connection to an AC outlet (120V). Make sure that all of the switches are off. After that, stop charging when two red and one green LED Battery Status Indicators light.
If you are recharging the unit from a 12V battery, do not charge for more than 6 hours. (Check for a full charge by disconnecting the DC charging adapter and then press the Battery Power Level button.)
The manual for the Stanley J309 battery jump starter is available on the product page here: http://www.baccusglobal.com/stanley/j309.php . The direct link to the manual is http://www.baccusglobal.com/stanley/manuals/JUMPERS/J309%20MANUAL.pdf .
I hope this helps.
Dec 29, 2011 | Garden
How do I know if my Stanley Bar-Flex BF0109 work light is fully recharged?
Gerard, PLEASE contact me at (941) 391-5152 or WFBanach@aol.com so I can hire you to replace the batteries in my Stanley barflex bf0109 light like you did above with vastly more run time mAh. I need someone to do it for me. I'm disabled. I just joined fixya.
Thanks,
Wallace Franklin Banach...
Aug 27, 2011 | Stanley Garden
Need a replacement charger & instruction sheetfor the bar flex light bf0109
I need a replacement cord to recharge my Stanley Bar Flex, Model #BF0109S, 6Vote DC-600mA. Is this something I can purchase from you?
I can be reached at 207-395-4721 or you can email me at: jawperk@aol.com
Thank you for your prompt attention.
Jane W Perkins
East Winthrop, ME 04343-0373
Dec 21, 2010 | Stanley Camping, Backpacking & Hiking
I bought A Stanley 450 jump start & I'm to charge it for 24hr. The 2 red lights are on but the green light is still blinking after 14hr. What does the blinking light mean?
not sure if you found this yet but it is actual made by Baccus Global under the stanley name.
http://www.baccusglobal.com/faq.php
Q: How do I know when my Jump Starter is fully charged?
A: All of the Baccus Global jump starters have a battery status indicator, units can have 2 - 4 LED indicators when all of them illuminate and the green one flashes the unit is fully charged.
Dec 05, 2010 | Black & Decker Jump Start System 450 Amp...
I have a stanley 300amp jump starter with no manual. When you plug it to be charged how do you now it is charged
i gave someone a jump start with my stanley j300 now none of the status lights work or the light on the side. how do i fix this?
Jul 08, 2010 | Computers & Internet
Garden Logo
16 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Jim Goldsmith
Jim Goldsmith
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Stanley Garden Expert? Answer questions, earn points and help others
