Question about HEALTHRIDER R60 SoftStrider Treadmill
My healthrider r60 has no power at all - HEALTHRIDER R60 SoftStrider Treadmill
How do you check actual mileage on a Healthrider r60 treadmill?
I dont believe it is possible. Not many brands worldwide give you this option.
Jan 02, 2013 | HEALTHRIDER R60 SoftStrider Treadmill
How to remove front roller so I can replace the walking belt
This is really tricky job. If you don't want to damage anything it may be wise to call a repairer. It won't cost much ,but worth it.
Jan 21, 2012 | HEALTHRIDER R60 SoftStrider Treadmill
Soft strider by healthrider tread mill does not function and the error code PO comes up any suggestions?
1) Please exchange batterires for a new ones.
2) Tight the flexible cables from keypane vs display board.
3)Tight the connector from display board vs lower board(Main motor board)
4)Adjust the reed sensor switch by 1/8" or 3mmsSee the diagram attached.
5)Measure input voltage for 115 Vac to input of main motor board
6) Measure input for power supply for +5VDC to main motor board.
7)Measure output voltage for +5vdc to Display board.
8) Finally see the block diagram that I am attached that I did for people like you. For easy diagnostic and troubleshooting.
Sincerely. Merry Christmas.
Ernesto CuaddraManagua, Nicaragua.12_24_2011_4_58_14_pm.gif12_24_2011_4_58_29_pm.gif
Dec 23, 2011 | HEALTHRIDER R60 SoftStrider Treadmill
Incline motor stays on going down, and will not respond to the controls. healthrider R 60
could be bad incline sensor or c/board is going bad. one more try bipassing the board with power to the incline motor fully powered 18volt batt will or higher will move the motorby flipping thr wires on the bat the incline should go up and down. if working ok then check board
Mar 16, 2011 | HEALTHRIDER R60 SoftStrider Treadmill
Master card to start
It appears the control board is still available.
Go here http://www.iconservice.com/CustomerService/partsModelSearch.do
And put in HCTL07120 in the model number section. this will give you a parts list. If you need an exploded diagram you can go here.
http://www.iconservice.com/CustomerService/manualsProductList.do?manufacturer=&model=hctl0712&modelName=&language=&x=38&y=9
Good Luck, Tim
Jul 17, 2010 | HEALTHRIDER R60 SoftStrider Treadmill
Healthrider r60 stops when it reaches 4mph.
Unplug unit and remove the motor shroud you will have to do DC Amp Measurement.
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Jun 28, 2010 | HEALTHRIDER R60 SoftStrider Treadmill
HEALTHRIDER R60 SoftStrider Treadmill Logo
Top HEALTHRIDER Exercise & Fitness Experts
Shehu Pro
Shehu Pro
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
