Question about Radio Shack Televison & Video
Need software for multimeter cat # 22-039
Cat number 22-039
I need a serial number. Simanco Cat RFJ-8
Serial numbers are unique to each product on an individual basis for tracking reasons. So there is no way we could know the serial number.
Apr 24, 2017 | Cat Computers & Internet
There is no power to the coil
If you have a multimeter you can OHM out your coil. You can call or e-mail Artic Cat for OHM specifications. If your coil ohm's out good.. check your Alternator for power output.
Jun 25, 2015 | Arctic Cat 2007 500 4x4 Automatic
2005 Nissan Altima 2.5L - where is the heated oxygen sensor number 2 located
Oxygen sensors are mounted either side of the catalytic converter. Number 1 is mounted before the cat in the down pipe and the Number 2 is in the exhaust pipe just after the cat, think the number 2 is the downstream.
Jan 05, 2014 | 2005 Nissan Altima
Which cat is bank 2 on 1997 gmc sierra 1500 4x4 5.7 vortec
Bank two is the side with cylinder number two, which in your case would be the passenger side.
Sensor one is in front of the cat, sensor two is after the cat.
Feb 21, 2013 | Cars & Trucks
How deep should a cats bowl be?
The depth of a cat bowl depends on a number of variables, most importantly the number of cats using the bowl. I suggest placing a few bowls in various places around the house. This way you can be sure that each of your cats will have water when they need it. The bowl should be large enough that your cats whiskers do not touch the sides of the bowl.
Aug 26, 2012 | Alessi Cats
What's the best treat for my cat?
For me the number one treat for my cat is Tuna Flakes. My cats go absolutely nuts when they see me with the treat in my hand, and I need to hide it to prevent them from eating it by themselves.
Aug 07, 2012 | Cats
My 2003 YZF-600r wont start. i turn the key to on on the lights turn on also then with it in neutral i hit the start button and everything turns off
Hi, Lance in order to check out any main electrical system, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary. "WARNING" never plug or unplug any electrical connector with the engine running !!!
1. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
2. Check the voltage drop at the battery when you hit the starter button, anything below 9 volts you might have a faulty battery.
3. Check voltage at the battery with the bike running at 3,600 RPM should be 14.3 to 14.7 volts. If you are not getting these numbers, you might have a faulty voltage regulator.
4. Make sure voltage regulator is "GROUNDED" and functioning properly, watch the video below on how to test a voltage regulator.
5. Unplug the connector to the alternator and hook your multimeter leads to the alternator (pin/socket selection does not matter) set the multimeter to AC volts, at an idle the multimeter should read 16 to 20 volts AC. at 2,000 RPM 32 to 40 AC volts, 3,000 RPM 48 to 60 AC volts. If you are not getting these numbers, you may have a faulty rotor, follow step 6
6. Set the multimeter to OHM'S, connect one lead to the alternator (any pin/socket) and the other to a ground, the multimeter should read infinity. Connect both leads to the alternator multimeter should read 0.1 to 0.2 OHM'S. If you are not getting these numbers, you have a bad stator.
7. Check all wiring in the charging circuit for worn or chaffed spots and all wiring connectors in the circuit for corroded, broken, or loose pins/sockets, which is the # 1 offender.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZF600R Forums View topic Battery dies while riding
HOW TO CHECK YOUR CHARGING SYSTEM and CHANGING the STATOR and REGULATOR...
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
Apr 05, 2012 | 2003 Yamaha YZF 600 R thunder cat
I have a 01 yzf600r and durring a ride the engine will loose spark and will cut off if i let it sit for a while it will start back up but the relay assembly 4tv-81950-00-00 starts clicking
Hi, Arnielsen in order to check out any main electrical system, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary. "WARNING" never plug or unplug any electrical connector with the engine running !!!
YZF600R Forums View topic cat won start relay just clicks
YZF600R Forums View topic Bike won start SOLVED BIG THANKS TO CHIN
Aug 25, 2011 | 1997 Yamaha YZF 600 R thunder cat
I was told it was front as well for my 2000 nissian maxima gle. Can someone please tell me which one and what location. Some are saying I have three conveters. I need to know specific location so that I...
you need the front exhaust tube, that has cat build into it. however all you may need is a ECM (computer) reprograming done depending on the part number of your current ECM. There are software updates for your p0420 but the reprogram data has to match in nissan database to see if all you need is a reprogram. if it does not apply, than you will need front exhaust tube and most likely 02 sensor.
Dec 08, 2010 | 2000 Nissan Maxima
Electrical? Carbs? Battery?
Hi, Jeannette in order to check out any main electrical system, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary. "WARNING" never plug or unplug any electrical connector with the engine running !!!
YZF600R Forums View topic Charging system
May 16, 2010 | 1996 Yamaha YZF 600 R thunder cat
Televison & Video Logo
32 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
