Question about Garden
Kubota l2500 hi lo shifter will not stay engaged on the hi side
Tractor will move fine in the lo range but as soon as tHe hi range is engaged it slightly attempts to move and then jumps out of gear. Cannot hold or force it to stay in gear. What is the likely problem
  • 376 Answers
SOURCE: Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
Posted on May 26, 2009
  • 138 Answers
SOURCE: Transmission reverse and 1 st gear, 20 hp
transmission and shifting problems are tricky. from the limited information given, i'll go on assumptions - if this is a hydrostatic transmission, your brake is stuck, it will need to be adjusted - if it is a six speed, several factors come into play. if it will shift okay with the engine OFF, but not with it running, you have a belt problem. has the belt been replaced recently? is it the correct belt? is the belt routed correctly? if none of the above, check the belt guides to make sure that a stick or something hasn't poked up there and bent them. their purpose is to make the belt "blossom" away from the engine pulley so there is no tension on the belt at the transmission. if it won't shift with engine off, the shift shaft in the trans is probably rusted and sticking.
Posted on Aug 16, 2009
SOURCE: Hi, looking for a manual for a Kubota ZB1-16
hi looking for a free website for a manual for kubota z48 engine workshop manual help me please
Posted on Sep 10, 2009
  • 394 Answers
SOURCE: shifter handle is lock in reverse. will not move
The gears are crossed up in the transmission.
You may get lucky if you try with the engine OFF,turning the trans pulley in the direction opposite of which the motor turns. This might unlock the internal gears.
Sorry for your problem. I know it is time to get the ground ready.
Posted on Mar 13, 2010
  • 146 Answers
SOURCE: starter gear doesn't move up to engage flywheel gear when started
The solenoid does two things -- it closes an electrical contact to run the starter motor, and also pulls a lever to slide the motor gear up to engage the flywheel. Since the contact is closing, the solenoid itself must be OK, but the lever could be broken, or the sliding gear could be binding or stripped. Since you're looking at a probable replacement, try cleaning with compressed air, then squirting some WD-40 into the starter gear area - you could get lucky! Otherwise, you can replace the starter/solenoid assembly -- you can find replacements on eBay for about $80. Less expensive but more time consuming is to remove the assembly, disassemble, and replace just the defective parts if you can find them. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 15, 2010
Does Kubota tractor have a low pressure switch & high pressure switch for air conditioner
You might have a TX valve and switch on the evaporator side. There should ought to be a low pressure switch in the hvac circuit to prevent compressor from running when freon is below operating pressures. Have you had the chance to hook up a/c gauges to get hi and Lo side readings?
Jun 20, 2016 | Kubota Garden
This is Kubota L4150DT tractor. the Brakes are wet brakes. that need replaced. could I please get a free PDF repair manual. that shows how to replace the wet brakes.thanks
Hi Simon I googled (user manual for kubota l4150dt) and got this links below, The manual you're looking for ranges in price from $9.95 to $95.00 I didn't see any free downloads, I also noticed the manual you're looking for has 4 model number in it L3350, L3750, L4150, L4150-n... Hope you find what you're looking for..CHEERS..
https://www.google.com.au/search?q=Kubota+L4150DT+tractor&oq=Kubota+L4150DT+tractor&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8#q=user+manual+for+Kubota+L4150DT+tractor&start=0
Mar 25, 2016 | Kubota Garden
98 Grand cherokee all time 4x4 wont shift into 4 lo
older post 1month
you failed to say what tires are touching, dry pavement or ice/snow or off road...... MATTERS big time.......!
the operators guide tells you not to do that.
the rules for 4Hi and low are different. RTM? yet?
last year ZJ
Quadra-Trac(tm) NV242 box. it is. full and part time box.
what does it (oper guide)tell you.
stay out of part time on dry roads. (clear?)
rule 2, save rule for Low Range.
low range is not full time 4wd.
if you fail to believe it , it will wind up and go crunch
here is the direct quote.... see last line,,, its 100% real.
25794037-bn3fg1eepmrl330iewfulw43-1-0.jpg i you had the NV231 box, all gears are Part time, all 4wd gears stay off dry pavement.
Jul 23, 2015 | 1998 Jeep Grand Cherokee
2008 rhino 700 stays in low range even when shifter is in high revers light stays on and speedometer inop
Check the gear change lever where it joins onto the side of the engine/gear box. Could have slipped off or stripped the splined shaft. If that is fine and when you move the hi/lo range, and the shaft on the gearbox moves its possible the gear change mechanical levers have broken on the inside of the box.
Jan 14, 2014 | Yamaha 2008 Rhino 700 FI Auto 4x4 Sport...
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
