Question about LG Cell Phones
It reads do not unplug device until the process is complete download mode
I put in wrong code and now it says disabled connect to iTunes but I set the phone up with wifi so how do I get in my iPhone?
Your iPhone is currently on disabled mode after entering wrong combination of password. There are several ways to gain back the access to your iPhone:
First Method: iTunes
1. Using your computer, open iTunes where you have recently backed up your iPhone.
2. Connect your iPhone. Once your iPhone is detected, a notification will appear to enter your passcode. Note: If the lockscreen doesn't show, proceed to next method.
Second Method: Update
1. While your iPhone connected to iTunes, powered on. Hold down the Power key + Home button simultaneously until the screen off, keep on pressing the Home button then release the Power key until iTunes detected that your iPhone is on Recovery Mode. Note: An iTunes logo will appear on the iPhone when Recovery mode is enabled.
2. On iTunes, click on Update iPhone. It may take a while to download the software, so leave it for a while connected until the installation complete.
3. Once updated, try unlocking your iPhone. Note: If you still can't unlock your iPhone proceed to next method.
Third Method: Restore (last option)
1. If method 1 and 2 fails to unlock your iPhone. Then try to restore your iPhone into its factory default and restore your backup after.
2. Go to recovery mode. See method 2 step 1 process to enable recovery mode.
3. Then choose Restore iPhone. Note: Restoring your iPhone will delete and remove all of your data including apps, music, photos, messages, contacts, notes, etc.
4. It may take a while to download and install the software, so leave your device connected until the process complete.
5. After your iPhone has been restored, choose restore from a backup or iCloud, then wait until your iPhone successfully synced your old data.
6. Try unlocking your iPhone.
-joshd
Mar 28, 2016 | Apple iPhone 5c
Tip
Jailbreak Apple iOS7.1.1 download links available for iPhone.
Jailbreak 7.1.1 available for download. You can download/install jailbreak utility for Windows. You can read the instruction with complete guide "How to jailbreak iOS 7.1.1". Don't forget - it's unofficial Geeksn0w jailbreak utility from jailbreak developer. It's tethered way for jailbreak iPhone 4 running on iOS 7.1.1. if you want see last information about jailbreak 7.1.1 for iPhone 5S, 5c, 5, 4S or iPad models - read here.
Microsoft. Net FrameWork, Java RE 7 and Java JDK Tool x86 ( 32 bit) , even if you have installed 64-bit Windows
2) Download GeekSn0w v2.8.3
3) Turn off your antivirus and firewall, otherwise the system will delete the files needed for the process .
4) Open GeekSn0w and click Jailbreak, choose the model of the device and turn your iPhone into a mode DFU. Model your iPhone you can see here - http://support.apple.com/kb/ht3939
5) Press the Jailbreak button
6) Wait until the process ssh_rd tool, if the process is successfully completed , you will see a green sign which notifies about the success of the operation
7) The device reboots and goes into recovery mode
8) Wait for the system files and will mount the boot process Jailbreak
9) Once the process is complete, you will see that your iPhone is in recovery mode
10) Wait until GeekSn0w introduce the iPhone in DFU mode and load it through the utility OpenSn0w (It takes a while)
11) You see what many call "The Matrix Screen" - matrix screen .
12 ) Re-enter the device mode DFU.
13) Now when the device is turned on, you will see shop Cydia .
14) You should let Cydia download all the necessary files and settings before it becomes functional.
15) Done!.
For More Info, visit Jailbreak 7 1 1 download links available for iPhone
on Jun 10, 2014 | Apple iPhone Cell Phones
Wipe my data partition
you need to boot into recovery mode to wipe the data partition. Doing this will reset the phone's data partition. Doing this will delete all data off the device and return it to the same state it was in when you first powered it on.
  1. completely power off the phone
  2. press and hold the power, volume up, and home buttons until you see the Samsung logo
  3. use volume up/down to scroll and power to select
  4. scroll to and select wipe data/factory reset
  5. select yes on any following prompts
  6. reboot device
If the above process does not work on your device, see alternate methods to boot into recovery mode in the following link.
How to Boot Samsung Galaxy Devices into Download Recovery Mode
Oct 18, 2014 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
I brought this remote and it doesnt have a code for my technika tv do you have an answer?
For Technika, pls try following code:
1171 1231 1261 0012 0432
or alternately, please try the magic search code as follows: 1. Turn On your device (LCD TV) 2. Press device mode (TV) from your URC (universal remote control) 3. Hold (P+ or Ch+) and (Vol -) on URC at the same time for two seconds until indicator lights up 4. Enter "magic search" code - press device code (TV), then press (P+ or Ch+) and (Vol -) on URC, and enter device (TV) magic code # 0001 5. Press device mode (TV), same or repeat process # 2 6. Hold (P+ or Ch+) and (Vol -) on URC at the same time for two seconds until indicator lights up and your URC is ready to start searching. 7. Aim the URC at your device (LCD TV), press the POWER KEY repeatedly, slowly and patiently until your device (LCD TV) switched off. 8. Once your device has been switched off, immediately press (P+ or Ch+) and (Vol -) to lock in the code and the indicator should go out. 9. If fail, please try complete process from 1 till end.
Hope it works, since it works for me.
Jul 02, 2011 | Televison & Video
How to resetter error p07 for printer canon mp258
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press the button. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Note: It may be necessary to unplug the power cord and retry if the above steps do not clear the error.
Mar 01, 2011 | Office Equipment & Supplies
Printer maintenance
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp190#ServiceAndSupport
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press the <ON> button. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON> button again.
(This is for 2,113,0 error not 2,114,0 error which isn't listed.)
Aug 03, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Upon installing player the computer was turned off by accident and in the process may not have installed correctly so now when i connect the device it does not read it and the device is stuck in...
Go to "http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2559"
To update the firmware of the M42xx mp3 player click hereand download the firmware. start the firmware and when it is runninplug the M42xx in at the same time holding down the PLAY BUTTON(center) until a white screen with a small computer with a line goingto your M42xx is displayed and then release the PLAY button. You canthen click on start and the firmware update will complete,,, DO NOTDISCONNECT DURING THIS UPDATE... it may take 2 times to complete thisbut it will work.... YEA!!!! WORKS with 2, 4 or 8 GB Models.....
Nov 30, 2008 | RCA M4208 MP3 Player
Sansa 260
this is how to do it READ EVERYTHING DONT SKIP THING
Switch your Sansa E260 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Retail/Default.aspx?CatID=1449
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred.
Step 3:
When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your E260 and 90-99% of the time, it would boot up successfully.
Step 5:
Enjoy using your Sansa E260, just like I do. (I love this player)
sorry for so much writing it pays off read this to
) Unzip the downloaded zip file and extract the file pp5022.mi4
2) On your Rhapsody device, go to "Settings" -> "Mode" then select "Rhapsody"
3) With the data cable, plug the USB connector to the USB port on the PC, verify “Connected” is shown on the e200R display
4)On the PC, Check for device “Sansa e200 (E:)” under My Computer.
NOTE: the actual drive letter might be different
5) Drag and Drop pp5022.mi4 from your PC to the root folder of E: drive.
NOTE: Do NOT drop it to “Sansa e200R Rhapsody” device which is the MicroSD card slot
6) Unplug your Rhapsody device.
7) Your Rhapsody device will restart and perform a firmware upgrade and restart again.
When done, go to main menu “Settings” -> “Info” and verify the current version number.
enjoy
Nov 13, 2008 | SanDisk Sansa e250 MP3 Player
New songs= black screen
try to remove the battery, wait 30 seconds and replace it
this should reset your sansa,
a real hard reset isn't possible,
you can format it though
warning, this removes everything
To format your Sansa E200 series MP3 player:
1. Open "My Computer."
2. With the player plugged into the USB port, right-click on the player (if in MTP mode) or the drive letter for your player (if in MSC mode) and select "Format" from the right-click menu.
3. Press "Start."
4. You will receive a warning that the format process will erase all data on your device.
IMPORTANT: Make sure you have backed up all of your data from the device before continuing with the format. Procedure will erase everything off the player. Agree to the warning.
5. The format will complete. Close the format window and your player should be ready to use.
After the format, please install the latest firmware update for your player. Please visit the following link to download and upload the Firmware on your Sansa E200:
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00...
PLEASE NOTE: All files will be deleted. Backup your files. Your MP3 player must be in MSC mode before installing the Firmware update.
To set your player in MSC mode, please do the following:
1. When the player is turned on, press the “Menu” button.
2. Navigate to the “Settings” menu.
3. Navigate to “USB”.
4. Under the “USB” menu, go to “MSC”.
After changing the player to MSC mode, reconnect it to your computer. The screen on the MP3 player should read “USB Connected” and "MSC”
You can now complete the Firmware update download from SanDisk.com on your device.
Installation Instructions:
1. Unplug any other USB flash drives that's connected to any of your USB ports.
2. Download the firmware to your PC
3. Plug in your e200
4. Double-click on the downloaded firmware (e200fw01.00.12.exe) and follow instructions
5. Unplug your e200
6. Device will do it's own update process and will restart.
The device should be ready to be used again.
Dec 16, 2007 | Audio Players & Recorders
Cell Phones Logo
35 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
