Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Fridge door is lower then freezer door
The refrigerator door to my kitchenaid superba is slightly lower than the freezer door..can someone tell me how to raise the door
  • 585 Answers
The #1 cause for this problem: The floor beneath the fridge is uneven, causing the refrigerator "box" to be out of square. Adjust the levelers on the fridge bottom to compensate for the uneven floor. That should do it.
Posted on May 19, 2009
Water collecting in bottom of refrigerator? where does it come from? How do you stop it? We have a Kitchenaide superba freezer over refrigerator 21.5 cubic feet total.
most common cause is condensation(fridges are not frost free).check door seals and that the kids have shut the door asap.also make sure you use a spirit level to square up the unt so that the door seals are tight allround....lastly,cover all food and put kitchen paper under salad/fruit drawer to catch water droplets(condensation)
Apr 12, 2010 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Mar 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
My refrigerator door won't close. How do I know if it is a hinge problem? How do I fix a hinge problem?
Newer model KitchenAid refrigerator doors have a two piece cam on the lower hinge that assists the door in shutting. This cam is made of plastic and the weight of the door tends to grind away this part quickly. To see if you have the cam and it's worn, lay on the floor and compare the freezer door to the fridge while someone opens it. If the cam is there, you'll see the door rise up about a 1/4" when you open it.
If the fridge is a newer model, a call to KitchenAid customer service will get you the parts. If it is out of warranty, they will send you the parts for free if you politely point out that an expensive fridge shouldn't fail like this so quickly.
This is an easy part to part to replace, though it does require taking the door off to do it. Screwdriver and a small socket set is all that is required. 15 minutes to complete the task, including taking the fridge contents off the door. :-)
Jan 17, 2010 | KitchenAid Superba KSRG25FK Side by Side...
How do you replace the water filter on a Kitchenaid Superba refrigerator. I can find the filter.
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
Oct 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Right door is lower than the left how do i level doors
if the door is slightly off u need a shim that will fit or a couple of small washers over the lower door pin remove food from door and with help from someone -to help in removing door and replacing it - at the top of the door u will c the upper hinge pin remove cover if one remove the 3 hold down screws while supporting the door remove hinge lift door off lower pin place shims or washers on lower pin till desired height not more than 3/8 is advisable place door on if still to low remove door and remove lower hinge and slightly give it a bend or leave on and slightly bend up hinge when desired height reached replace door and reattach top hinge
Sep 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchenaid fridge #KSCS25INSS hot door frame
There are heaters located inside the door frame, to prevent your doors from freezing shut, and also to prevent condensation on the outside of the appliance. It sounds to me as though that is where your problem is... Hope this helps
Sep 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Apr 24, 2009 | Refrigerators
Kitchen aid superba door problem
HAVE YOU TRYED ADJUSTING THE TOP HINGE?MIKE
Oct 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Handle loose on Refrigerator
I have same problem. Just called KitchenAid and they told me I needed a T-20 torque key - you can buy it from them or at a hardware store. Good luck.
Jun 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Superba kitchenaid fridge not very cold, freezer is fine
do you have any frost build up it the freezer back wall... fan blowing in freezer and in back ...condeser coils clean... if all the above is ok ...must have temp. sensor or themostate cold control problem
Sep 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
565 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
