Question about Toshiba 57H84 57" Rear Projection HDTV-Ready Television
Vertical lines in model number 57H84 how can this be fixed
Just vertical lines
3 Suggested Answers
  • 336 Answers
SOURCE: My five year old Toshiba 57H84 rear projection TV
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Posted on Apr 30, 2010
SD Tech
  • 14553 Answers
SOURCE: vertical lines showning on 57H84 have been told itis the bulbs need to be clean.If you think the same p lease tell me where and ho to look and cleanPlease.
You may have one of two issues here--noisy lines when set first comes on left to right---they clear up after 10-15 minutes.
Other possible is a convergence problem--colored lines, 3 d looking etc--see typical photos attached---Problem does not sound like a cleaning issue--
let me know which issue you seem to have with a comment here.
SD TECH
Posted on Apr 26, 2012
When you turn on set a lot of vertical scramble lines
Turn off, disconnect power for a couple of hours and try it again.
If vertical lines still there google for your model number and vertical lines. If it is an LCD version set then youtube search for your model number and repair. Sometimes it takes a baseball bat!!!!
Feb 10, 2015 | Televison & Video
My Toshiba HD tv Model 57H84 has vertical lines on screen it's worse when first turned on but clears up some after warm up but not completely. What causes this and how can I repair problem?
Bad connection on one of the boards . More than likely t-con board , if not that then may be moisture on the main board around the chip , processor . Give it a wipe
Nov 16, 2012 | Televison & Video
I have a 57H84 toshiba I bought new in 2004 I have lines from top to bottom approx 1 in apart.I have been told that is the bulbs that need to be cleaned .Can you tell me how to get in to the bulbs and...
57h84 IS A REAR PROJECTION SET WITH 3 picture tubes.
you got lines in picture top to bottom on the screen running left to right?
They go away after a while?
Apr 26, 2012 | Toshiba Televison & Video
Vertical lines showning on 57H84 have been told itis the bulbs need to be clean.If you think the same p lease tell me where and ho to look and cleanPlease.
SD TECH
Apr 26, 2012 | Toshiba 46H83 46" Rear Projection...
Vertical lines on screen of Toshiba rear projection Model 57H84
Check for bad capacitor in vertical circuit where vertical IC is LA7833.
100uf 35v 1uf 50v 2.2uf 25 47uf 50v
Dec 03, 2010 | Toshiba Televison & Video
Picture flutters vertically
Many of these sets (57H84 etc) had a problem with the "Hyper" board.
It is a circuit in the set that processes all signal from the tuners, and all inputs.
Most of the time this problem shows up when the set is first turned on and after several minutes the picture goes to normal----the delay if you have this problem slowly gets longer and longer.
The hyper board is NO LONGER AVAILABLE-and the only way to correct it is remove it and send it out for rebuild.
There are about a dozen very small "surface mounted filter caps" on the board that dry out and cause the problem.
2 people with this problem were able to remove the board and replace all the tiny caps but IT IS NOT EASY AND NOT A TASK for a do it yourself person unless you have some real skill.
The problem usually looks like noise lines from left to right across the whole or part of the screen---if it started gradually---it is a bad Hyper board.
Let me know by responding with a comment if you need help or advise.
SD TECH
Aug 04, 2010 | Toshiba 57H84 57" Rear Projection...
My five year old Toshiba 57H84 rear projection TV has a pink tinted screen when you first turn it on, then after it warms up, the colors are all fine but then the picture has evenly spaced blue tinted...
Apr 30, 2010 | Toshiba 57H84 57" Rear Projection...
Replace board toshiba 57H84
They are located on the large signal board in the middle of the board all lined up in a row they will have board location numbers of 7412, 7406 and 7413
Nov 23, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
