Question about TruTech PLV16320 Television
NEED POWER SUPPLY FOR TRUTECH PLV16320
The power supply is not repairable. Anyone know a supplier for these parts. Funai does not make this model.
  • 557 Answers
Try shopjimmy.com or you may be able to find one on ebay.
Posted on Oct 07, 2009
    Champion:
  • 367 Answers
What is wrong with your power supply?Please let me know.Thank You very much!
Tyler
Last evening, my television puffed smoke then stopped working
Deffective power supply its a major repair,Theres a shorted parts in power supply.Need for repair technician.Who knows and troubleshoot the power supply.
Jul 11, 2011 | Funai F42PDME 42 in. Plasma Television
Tv will not turn on
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed (EX: backlight inverter)!
Please rate if this helps! :D
Replacing capacitors is ALWAYS the cheaper option, but you need to have experience it, or you'll create more damage than good!
May 11, 2011 | TruTech PLV16320 Television
Where can i find a a power suply for a 32'' PLV16320 TREUTECH
Tyler
Apr 16, 2011 | TruTech PLV16190 Television
TruTech PLV16320 power suply
Tyler
Sep 21, 2010 | TruTech PLV16320 Television
PVS21175a1 TruTech 17" LCD TV
call mfg ask them where to buy they have repair depos thet carry the supply in your area
Aug 04, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Can't find parts
You shouldn't have to buy a whole new board.Look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Jan 24, 2009 | TruTech PLV16320 Television
TV won't turn on
If that large capacitors is defective, the TV should still power up normally but it might produce a humming noise through the speakers.
I would suggest to check very carefully the capacitors on the secondary side of the circuitry, specially the 1000uF that filter the 5vdc line.
Let me know if you require further assistance.
Dec 02, 2008 | TruTech PLV16320 Television
Trutech TV PLV16320 - Power Supply Caapacitor Values
I take it you didn't save the capacitors?Or you just don't know what hole they came out of?I have someone that is supose to be sending me their power board from the same model TV.When I get it,if I do,I will let you know what they are.I did replace the bad ones on a 26" Trutech,and to me,they appeared to have the same board.If you wanted to take the chance,and replace the ones I did,here is what they were.Mine had three different diameters as well,but two had different voltages,and height.The measurements read diameter,and then height.(2) 35V 1000UF 13MM X 22MM (1) 25V 680UF 10MM X 16MM (1) 35V 680UF 10MM X 20MM (4) 10V 1000UF 8MM X 14mm When you do go to replace them,you can get ones with a higher value on both specs,but not lower.For example,if there is a 10V 1000UF,and a 16V 1000 UF,you can replace them both with 16V 1000UF,and it will work perfect.You can also use different heights as well,as long as there is enough room.How is the big black 450V 150UF,and the 400V 10UF capacitors?You have to check the bottoms of them as well.I had fixed one that these were the only two that were bad.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Oct 17, 2008 | TruTech PLV16320 Television
USED TRUTECH TV
you have a high voltage problem I would guess its in the power supply B+ voltage is missing hope this helps you.
Sep 15, 2008 | TruTech PLV16320 Television
TruTech PLV16320 LCD TV
Hi
I like to know if the power supply transformer was buzzing when this caps burned , I"am responding
on bandita's 2012 e-mail regarding her TV that has no piture or sound and no red or green indicator lights, the power button does
not turn the TV power off regarding the transformer buzzing.
Thank you RichE
Jun 18, 2008 | TruTech PLV16320 Television
TruTech PLV16320 Television Logo
382 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
