Question about Apple MacBook Mac Notebook
Battery won't charge. Replaced battery, charger and DC Input board
Battery won't charge. Bought a new battery and a new charger. The I purchased a new DC Input card from Fixya.com. That didn't help either. COuld it be the motherboard?
  • heyguyritter May 29, 2009
    Joe, that didn't work. No matter what I try if I go into the System Hardware overview and click on Power, it says the battery is not installed. The new DC Input board didn't help. Must be the battery compartment or the Logic board. I have a brand new battery and charger. This is a Mac Book Pro 13.3" Intel Core Duo bought in Jan 2007
  • 221 Answers
Please check this article at apple support:
http://www.apple.com/support/macbook_macbookpro/batteryupdate/
Thanks Damien
Posted on May 29, 2009
    Problem Solver:
  • 5 Answers
Blah blah insert witty technical sounding things here... If this is one of the white plastic body MacBookss, please refer to a intro to DC 101... No seriously now, clean your connections.... 3 places in particular, 1.) The pins at the mag charge port outside and in (get the **** that has built up over the years out and also where the mag board connects to the logic board) DO NOT REATTACH YET!!! 2.) Now look straight down the side of the board, where the battery connector attaches to the logic board <--- REPEAT STEP 1 (Don't get excited yet, this is called preventative maintanence) STEP 3 AKA THE REPAIR) Now start unscrewing that pesky ALUMINUM frame or as I like to refer to it as "the thing that connects the battery to the ground plain". Make sure to disassemble in as many places as possible and clean both sides of the frame as possible. NOTE: As you do this please refer to the pile of white powder the will begin forming on your work area. Don't get excited this not an illegal substance and does not hold any kind of street value... It's ALUMINIUM OXIDE... The sad byproduct of a combination of time and aluminum. The nifty thing aluminum oxide is that it does NOT conduct electricity. It's a fantastically thin awesome insulator. Seriously clean this framework and your pin connectors... Don't negate the sockets or copper pads on the boards either. Now reassemble, and be amazed as to how well that old battery still dances around any windows machine... Battery life issues many times may also be resolved by this repair. But Always remember to check for a "BULGED" battery, if your battery is becoming lumpy do yourself a favor and shop amazon.
Posted on Apr 06, 2012
  • Jay Dubbs Apr 06, 2012
    Sorry since this is one of the pro's concentrate on cleaning the ground plain.... The frame and spaces inbetween. Grounding grounding grounding. Make that frame shine and clean those copper pads also...
  • Apple Master
  • 4,338 Answers
The System Management Controller is an integrated circuit (computer chip) that is on the logic board of the computer. As the name implies, it is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Over time, the settings in the System Management Controller may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, not charging the battery, or not recognizing the AC Adapter, among others.
Resetting the SMC is not intended for resolution of a stall or situation in which the computer is unresponsive. An SMC reset should not be necessary except as a last resort in cases where a hardware issue with the power management system is suspected. Performing an SMC reset resets the hardware power management functions.
For most situations, a restart is sufficient. If the computer has stopped responding, try each one of these steps, one by one. Test between each step to see if it has worked. If one step works, don't worry about the next one. You should only reset the SMC if you've tried all of the steps listed here and the computer still isn't working.
  1. Force Quit (Option-Command-Escape)
  2. Restart (Control-Command-Power)
  3. Force Shut Down (press the power button for 10 seconds)
Only perform an SMC reset on the computer if none of the above steps resolved the situation. If this is the case, see below for instructions on locating the reset button or key combination for your model of computer. If your computer is earlier than the models listed here, see "Resetting PowerBook and iBook Power Management Unit (PMU)" or "PowerBook: Resetting Power Management Unit (PMU)".
MacBook, MacBook Pro except MacBook Pro (17-inch, Early 2009)
  1. If the computer is on, turn it off.
  2. Disconnect the AC adapter and remove the computer's battery.
  3. Press and hold the power button for 5 seconds and then release the button.
  4. Reconnect the battery and AC Adapter.
  5. Press the power button to restart the computer
Note: Starting with MacBook Pro (Late 2008) and MacBook (Late 2008) models, you may instead use the reset method for MacBook Air (below) to reset the SMC. All earlier models of MacBook and MacBook Pro must use the method described above, which involves removing the battery.
http://support.apple.com/kb/HT1411
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 20, 2009
When a tablet has a mark like this ! on a battery what does it mean?
Simply, it means that either the battery has failed and must be replaced - OR the charger is not working properly and is not charging it. Simple test is, does the tablet run OK when plugged into the charger, but not when running on the battery? If so, it's the battery. If it won't run even on the charger, then it's most probable that the charger is broken and will need to be replaced - or the DC input socket on the Tablet has broken internally or come loose from the circuit board, which is a repair shop fix I'm afraid.
Jan 02, 2015 | Tablets & eReaders
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Dewalt radio dc 010 will not charge
Check the voltage from the charger, check the socket which it plugs into for fractures and dry joints on the circuit board. Those are the most likely failure points. Have you tried moving the plug around to see if it's a bad connection?
May 12, 2014 | Audio Players & Recorders
Compaq A900 i replaced the dc jack the laptop wont charge bought new battery and charger and still wont turn on
A battery that will not charge may be as a result of an AC adapter failure, a system board failure, or a battery failure. You should therefore try to troubleshoot the power supply, the System Board and the battery. You can read more through the following site.
Sep 22, 2013 | Computers & Internet
Z1015 won't charge battery internally. this battery was working
Hello, Is the battery in the camera or in the charger ?? Don't quite understand the question. You wrote "received correct wall charger AC/DC ?" was that a question concerning the new charger ? it sounds like your not quite sure about the charger.
Best Regards, Russell
Dec 31, 2012 | Kodak EasyShare Z1015 IS Digital Camera
Gateway nv52 won't charge
It sounds like you either have a dead mother board or a bad power inlet. Did the machine work with the new battery while it was charged? If so, then the battery connector was good and the inlet was bad. If not, your motherboard could be dead. I've also seen where a bad battery connector would syphon off enough power to not power on the machine or charge the battery.
Nov 14, 2012 | Gateway NV5215u Notebook
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
Difficulty charging
Sounds like you have a bad internal dc jack. These go bad after so long. This is a normal problem on all laptops. Make sure it isn't your battery by seeing if you could use another same model battery. If having tried a new charger and a battery and the problem still persists then take it to your neighborhood computer shop or send it to me. I can replace the dc jack for you since you'd have to sodder a new one on.
Mar 18, 2010 | Acer Aspire 5570-2067 Notebook
Where can I purchase a battery charger?
A new product laptop battery charger
AC input:100-240V AC 50/60HZ
DC input:12-24V
High output:16.8V 2.5A DC
Low output:12.6V 2.5A DC
charge time:3-5h
color:black
That has be dead against use front happen problem and LI ion battery trait., when charge battery must take out use, has insure up to snuff on room temperature charge , as well as can avert happen blast or combustion or life reduce problem. simultaneity can let it is accomplish normally charge and discharge process the battery , It’s activation state urge LI ion battery inside is longtime. Can prolong use life the battery.
That has be dead against use two species battery voltage parameter at laptop IT trade, the product have setup switch switchover voltage, insure apply two species different voltage laptop battery charge, any more introduced commutator model the product DC output plug, can use different variety, let use charger electricize for laptop battery is safety and set one's heart at rest. And that can prolong use life the battery, best economize expenses which needless for the peoples.
It’s charge use AC to DC, DC to DC two model charger. May use in the home or office ,and car or ship or train. Usag is best convenience .
If you have need the product, please contact us
Mobile:13751018213
skype:lincen18213
Email:lincen18213@163.com
FAX:86-755-61573100
Feb 25, 2009 | Zenith ZPA-314 Portable DVD Player
Apple MacBook Mac Notebook Logo
2,100 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
