Question about Oster OGB61101 Microwave Oven
Oster 1000 watt microwave does not work
Does not work light and timer comes on but turntable and microwave does not come on brand new oven
SOURCE: Oven just died on me!
The same thing just happened to ours which is just one year new. Waiting to hear if anyone can offer suggestions/feedback.
Posted on Aug 27, 2009
  • 574 Answers
SOURCE: 1 yr old Oster 0.7 CuFt Microwave Model OM0701A stopped working
could be door interlock switches, door misalignment
Posted on Aug 29, 2009
  • 248 Answers
SOURCE: I am looking for the
appliancesupplies.smarter.com
Posted on Oct 12, 2010
localwonder
  • 6784 Answers
SOURCE: microwave turns on, but does not cook. the light
HI. Your symptoms are a strong indication Magnetron failure. This is the principal heating device, that is used to produce microwaves that , essentially, excite the water molecules in the food, thus, producing the heating effect. When this device fails, generally, the unit will run, but not heat. This device is very fragile, and can injure you if you are not qualified to handle this type of component. There is a High Voltage Capacitor, that is used to help provide the necessary current for optimal Magnetron operation. This capacitor must be discharged correctly. If not, you could risk serious injury, during the repair, if it is accidental touched.
The Magnetron is linked to a cut-off fuse. If the magnetron becomes unstable, this fuse will shut the device down. It is standard procedure to have this fuse test for continuity. If the fuse has blown, this will be the culprit. Replace the fuse. Now, if the fuse continues to show continuity, this will confirm that the Magnetron has failed. I would advise to inspect the Capacitor, and HV diode for visible burn marks, or swollen top(Cap).
Access can be ac hived to these parts by removing the outside cabinet screws. Once the screws are removed, the cover can be removed, as well. Once the cover is removed, the internal components will be exposed for testing, and visual inspections.
WARNING: IF YOU ARE NOT A QUALIFIED SERVICE TECH, THIS WILL NOT BE A NOVICE DO IT YOURSELF JOB. MICROWAVES ARE VERY DANGEROUS, AND CAN CAUSE SERIOUS INJURY. I RECOMMEND TO CALL FOR SERVICE, IF YOU ARE UNCOMFORTABLE WITH HANDLING THE CAPACITOR, OR MAGNETRON...
Posted on May 01, 2011
  • 405 Answers
SOURCE: microwave is less than a
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS
Posted on Jul 07, 2011
GE JVM1850 turns on but turn table doesn't rotate & light doesn't come on even though timer counts down. Doesn't heat & has low hum noise. Is it worth fixing or should I buy new? It is 8 yrs old.
if you like your micro fixe it, becouse even do new micros look better when it comes to work they suck they hardly last the warranty period thats if you are lucky...
Oct 19, 2013 | GE JVM1850 1000 Watts Microwave Oven
Microwave is less than a year old. It looks like everything is working, timer, light, air, turntable, etc., but it doesn't cook.
Jul 06, 2011 | Oster Microwave Ovens
Turntable is not spinning
This is a common problem in a lot of different brands, The turntable motor is defective and will need to be replaced to remedy the issue.
Mar 19, 2011 | Estate TMH16XS 1000 Watts Microwave Oven
My microwave lights up, turntable turns, timer works, everything works but it does not heat or cook anything??
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 16, 2010 | Whirlpool MT4110SKB / MT4110SKQ 1100 Watts...
Re. Viking DMOS200 1100 watts microwave oven does not turn on
I'm guessing that's a VMOS200?
If so, that's a rebranded Sharp R-530ES (as is the Dacor DMO2420S) and its secondary interlock (bottom door switch) or that switch's mount is bad.
See this file on door switches. If you only need a switch, you can order a universal type here for $5 postpaid.
The Sharp R-530E service manual will aid you in disassembly and it is here.
Jul 02, 2010 | Viking DMOS200 1100 Watts Microwave Oven
Microwave not heating
OK, you have two components that are faulty. the magnetron and the turntable motor as well. replacing these two components will fix both issues.
Jun 10, 2009 | Frigidaire FMV157GM Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Oster OGB61101 Microwave Oven Logo
Top Oster Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
NOEL
NOEL
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
