Question about Exo Terra Turtle Filter FX-200
The exo terra fx 200 is not pumping water - Exo Terra Turtle Filter FX-200
Why doesn't the filter work?
I would love to help you, but I too am having the same issue, although mines not even making any noise at all. At first I though I had a faulty filter, so bought another one, but that too is completely dead. I am all out of ideas, despite thoroughly following the instructions. I've bought a new 2 pin plug adaptor for it but that hasn't worked either.
Jun 15, 2015 | Exo Terra Turtle Filter FX-200
Euphorbia Trigona cactus turning yellow why
did you move it to a brighter spot in your home. reading about this plant I would not have one anyplace near people quite hazardous
Feb 26, 2015 | Hagen Exo Terra Jade Cactus Terrarium...
Where is the water pump located
They are usually mounted behind a cover panel behind the water fill connection in the under belly storage. Turn the pump on and open the water valve on the kitchen sink and listen for it to start vibrating.
Jun 23, 2014 | Fleetwood 2008 Terra 33L
Watersoftener salt tank keeps flooding
Sounds as if the head has a valve sticking, Need an overhaul kit that has new paddle valves with screen and injector also. Unplug unit, put into by-pass (3 valves above it) then manually rotate cam to depressurize head and tank, follow kit instructions to overhaul, or you may want to call a plumber.
Jan 02, 2014 | Water Reservoir
Cannot set combination
I recommend that you post your question under the correct category (home and garden maybe?). If you add more details to it, it might be easier for Experts to understand the question and answer it.
Jul 20, 2012 | Hagen Exo-Terra Terrarium Lock
How to troubleshoot this fogger
I would take it back to the place that you bought it or contact the manufacturer and tell them that it's not working properly.
But first i would make sure all the parts are secured in and the batteries are working properly.
Jun 18, 2012 | Hagen Exo Terra Mini Fogger
Exo Terra Turtle Filter FX-200 Logo
123 people viewed this question
Top Exo Terra Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you an Exo Terra Fish Expert? Answer questions, earn points and help others
