Question about Kodak 8mm Instamatic M67 and M68 Projector Service Manual
How do you load a Kodak instamatic m67 projector
Threading and showing the film
Usaly means that drive rubber bands have gone bad, Very hard parts to find anymore.
Nov 15, 2014 | Kodak Vintage 8mm Eastman Movie Projector...
How do I change the bulb?
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Jan 21, 2014 | Office Equipment & Supplies
Kodak m67 8mm movie projector struck in rev lever can be move to forward but miss run backwards
it is hard to explain but there is a metal pin on one of the mechanisms it can become bent out of place. you need to remove it and heat it up and put back straight. dont try to bend it straight as it will snap or the pin will come out of the metal part.
Oct 13, 2013 | Kodak 1950s/60s Brownie 500 8mm Movie...
User Manual needed for Kodak Instamatic 8mm M 50 Movie projector
try googling Kodak Instamatic owners manual . You may need the model number but you should beable to find and download the manual
Aug 27, 2013 | Audio Players & Recorders
Instamatic M67 Movie Projector
I'm not sure what your issue is here. If you are having a functional problem, please describe it with detail and I will attempt to assist you. Jim
Nov 25, 2012 | Kodak Office Equipment & Supplies
I have a kodak carousel model 450H and it will not advance or load the slide. All it does is click
Double-check that model number. Kodak did not make a projector with that combination of numbers & letters.
Aug 17, 2010 | Kodak Office Equipment & Supplies
Kodak slide projector Kodak 600 burning bulbs, fan is working
Excessively short lamp life is usually caused by material building up on the lamp socket terminals, caused by arcing. This material build-up causes higher current loads and will ultimately shorten lamp life. A new lamp socket is a simple solution to your problem!
Feb 16, 2010 | Kodak Office Equipment & Supplies
How do I open my Kodak Instamatic M70 projector?
I have a Kodak Instamatic M70 Super 8 movie projector. How can I stop the film from continously jumping? I have adjusted every nob and looked inside to find nothing out of the ordinary.
May 16, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Does bulb need replacement?
I had same problem.
You have to load the slides so there is something to be projected.
Dec 15, 2008 | Kodak Ektagraphic III ATS Slide Projector
Kodak 8mm Instamatic M67 and M68 Projector Service Manual Logo
27 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
