Question about Casio gr-8900a-7 g-shock gr-8900a-7er
None of the buttons on my gr8900a work - Casio gr-8900a-7 g-shock gr-8900a-7er
How do you "unfreeze" a champion c9 wrist watch?
I am having the same problem. The battery is fine, the seconds are ticking away, but none of the side buttons work. The light doesn't come on and nothing happens with any of the others either. The only thing that did work was pressing all four of the buttons simultaneously, which seemed to totally reset the watch. The problem is it reset but didn't fix the buttons. So now I can't even see the correct time anymore.
Nov 21, 2014 | Geneva Watch Group C9 by Champion Mens...
Nike Triax Fury: when replacing battery, 2 springs fell out (silver and a gold one). Where do these go and where were they from?
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Unfortunately, I can't add a photo or I would. Good luck.
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
How to shut off FLASH LT on g shock
Should be able to push light button again and it should go out
May 12, 2012 | Casio G-Shock GA-120A-7A GA-120A-7 Analog...
Hello , I own a timex iron man triatholon model no t5g691 , the problem is none of the buttons work . they only work when I press them all together to turn it off . I also went recently swimming with it...
this problem occur only if one of the buttons are stuck inside, because you cannot push two or more buttons at the same time unless that you have to reset the watch. 2nd probably the buttons of your watch didnot reached the contact inside, sometimes it needed to be cleaned and had to be lubricated. if still did not work. reset your watch using the reset button inside the watch. i hope this will help you a lot.
Sep 13, 2011 | Timex Ironman Triathlon Solar Powered...
I just bought this watch Nautica A31504 and it does not seem that any of the chrono buttons work. Is it the watch that is defective, or am I doing something wrong. In the manual, it says that I can...
The watch has been displayed for long time. You have to replace new battery for the watch and then those functions will work again. Good luck! :)
Feb 10, 2011 | Nautica A31504 Watch
All buttons don't work can;t put watch ahead one hour none of the four function buttons want to work watch is 6 months old . I don;t have receipt..
If you haven't got instructions, you can get them from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
May 10, 2010 | Timex Expedition 40141 Wristwatch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
Mar 17, 2010 | Timex Expedition 40141 Wristwatch
Casio gr-8900a-7 g-shock gr-8900a-7er Logo
59 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
