Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
Oven will not get hotter than 350
My maytag mgr4452bdb oven will only heat up to 350. the temp selection can go higher than that, but the oven will not get hotter than 350.
  • xenophanes May 11, 2010
    Now that is interesting!
    I'm curious how you measure the 350 degrees --- do you have or can you get an oven thermometer and try the following experiment...
    We don't want to use the built in oven thermometer, but an 'independent' source.
    Turn oven to 100 degrees or the lowest possible setting. Once the temp has stabilized, what does the independent source thermometer say.
    Move it up to 200 degrees, stabilize and test
    Move it to 300, stabilize and test
    Move it 350 , stabilize and test
    move it to 400,, stabilize and test
    get really greedy here and move it to 450, stabilize and test
    That experiment should point to the problem.... and probably the solution
3 Suggested Answers
SOURCE: Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Posted on Jan 28, 2009
mbnataraj
  • 84 Answers
SOURCE: Oven & broiler not heating on our Maytag
May be the heating coil is bust?
The control panel is in parallel usually so as long as the controls are getting power they will turn on. But if the coil is gone you wont get heat. If you want to try fixing it, you may need a multimeter, or a continuity tester.
Posted on Jul 08, 2009
Will not fully heat to temp setting; takes 2 min B4 gas ignition 2 heat.
Time for the gas valve to open fully can be a few minutes, I've seen them take up to 3 minutes to open, so its not unusual. Hoverer, the temp issue may be due to your burner's gas jets being clogged with ash, etc. Remove the burner and inspect, the holes or jets should be nice and clear, any clogged ones need to be opened use a safety pin or something similar to open, try no to make the hole any bigger then it is. You may also find it may light quicker since there will be less back pressure in the line once the jets are cleaned.
Aug 15, 2014 | Maytag MGR4452BDW / MGR4452BDQ /...
Oven set at 350 goes way higher
the oven sensor rod on the rear wall of the oven cavity is defective,remove screws holding it sometimes you can plug a new replacement sensor in from the front,if you can't then remove rear panel on the back of the oven to access the connector to replace it
Nov 26, 2012 | Ovens
I have a black Maytag Gas Range stove the oven wont heat up. The ignition what i think it is, is glowing but when I tap the bottom of the stove it will light. What part do I need and where can I get it....
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
Turn oven on, never heats. gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 03, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
I have a maytag MGR4452bdw gas oven. it will not heat up above 350 degs, what's wrong? please advise
first thing to check is the ignitor,remove the racks and remove the bottom inside floor,if anything else is there remove it so you can see the ignitor,set the oven to 350,if the ignitor glows but doesn.t ignite the flame in 40 seconds change out the ignitor,the reason why i say this is if the sensor or anything else would bring up an error code.hope this helps.
May 16, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
Oven takes approximately 35 minutes to heat up to 350 degrees.
if this is all the higher it heats,its one of 2 things,first the heating element could have a Hot-Spot on it somewhere(a dis-coloration) on the element and have a bubbly/pock marked area that ready to burn out and cont pass enough current to fully heat the element,number 2 it could be the thermocouple on the roof of the oven cavity that is bad and turning off heat before its to the heat you set,it looks like a long tube with a wire or smaller tube leading from it,its connected to the oven heat control and senses oven operating temp and cycles the heat on and off per your temp setting
Aug 01, 2010 | Maytag Kitchen Ranges
Oven temp maytag MER5770
check your element if thats fine u need to replace your erc and possibnly your oven sensor
Mar 19, 2009 | Maytag MER5770 Electric Kitchen Range
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
260 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
