Question about Mitsubishi LT-52149 52 in. LCD HDTV
Vertical lines in my LT-52149 Mitubishi tv
There are vertical lines to the left edge of the screen and in the middle. Narrow lines and a wide band of blue at the left side also.
3 Suggested Answers
jhinsincity
  • 616 Answers
SOURCE: I have a LT-46244 and there are two vertical black
No format burn-in if thats what you mean, tv needs to serviced. good luck Julio milleniumtvsvc@gmail.com
Posted on Jul 23, 2009
  • 16 Answers
SOURCE: Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Posted on Sep 20, 2009
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
Vertical white line in the middle of rca tv
Check and replace all the electrolytic capacitors at its vertical output section circuit.
Mar 17, 2013 | Televison & Video
Vertical lines blue
Check area around TV for interference--cordless phone--wifi---also check input cords and hdmi cable or coax cable--- make sure connections are tight and secure
Aug 18, 2012 | Mitsubishi LT-52149 52 in. LCD HDTV
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
Screen shrinks down to a narrow band of light in
You have bad grounds on the vertical IC. The grounds will need resoldering and check for weak caps near the ic.....they will overheat the ic...creating the bad grounds. Solder will expand and contract with heat and cooling of a tv. HMMMM you could also have a cold solder elsewhere on the board. Search and you shall find.
Aug 16, 2009 | Televison & Video
Green band
click warranties...
Jul 26, 2009 | Mitsubishi LT-52244 TV
Jul 23, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Mitsubishi LT-52149 52 in. LCD HDTV Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
