Need a paper roll holder el2192gii - Office Equipment & Supplies
4 Suggested Answers
  • 329 Answers
SOURCE: Replacement for broken paper roll holder
There are universal glue on paper holders available email upstateos@adelphia.net
Posted on Jun 24, 2008
  • 234 Answers
SOURCE: Broken Paper Roll Holder
You must google to find the manufacture to find if anything is still available; but I have 2 ideas : 1. form a hard wire loop (from coat hanger or #12 guage steel wire) and attach this wire loopto the back of calculator case with screws (you'll need to make an eye loop at one end for the screw to go through). 2. make a small wood block that sits on the desk or table and make a wire loop that is held by the wood block and of course the paper roll is held by the wire loop. Goodluck, Macgivor.
Posted on Dec 07, 2009
  • 23 Answers
SOURCE: The paper roll holder is broken on one side. Can
For most models, the holders can be replaced. You can try Universal Paper Arm Holders if you can't find one for your specific model.
Posted on Mar 26, 2010
Testimonial: "Speedy response with accurate information"
How do you replace the thermal roll to get it to print
Make sure you are using thermal paper which is 57mm wide.
Open the printer cover. Lift the paper holder lever on top of the printer. Remove the old tube from the last roll if it is still in the bottom of the printer. Drop the new roll into the roll holder in the bottom of the printer. Make sure the paper is coming from the bottom of the roll rather than off the top as it unwinds. Pull the paper out the front of the printer and close the paper holder lever down onto the paper. The shiny side of the paper should be facing you as it comes out of the printer. If not, the paper will feed out blank during printing. If you are replacing the journal roll, slip the end of the paper into the slit in the takeup spool (black reel) and wind over a couple of times before dropping into place. Replace the printer cover and make sure the receipt comes out of the cut out in the cover.
Good luck.
Jul 11, 2015 | Casio PCR-T2000 Cash Register
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    I have cash register machine name : towa sx 680 how can i change both the rolls Kindly tell me in steps i shall be very thank full to you Regards
    Open the flap in front of the printers. Press the release button inside. The paper holders will pop up. Sit the new roll in with the paper coming from the bottom of the roll. Pull some paper out to the front of the machine and close the paper holders. For the journal roll, you will need to thread it onto the black takeup spool and wind it over a couple of times, then drop the spool in the holder. that is the best I can do for a description. If you need more information, the Towa / Geller SX-680 manual is here: http://the-checkout-tech.com/manuals/cashregisters/Towa_SX-680_operation_programming_manual.html
    May 22, 2011 | Casio Parts Cash Register PC Desktop
    How do I change the paper tape roll on casio HR-100TM?
    Pull about a foot of paper loose from the roll so it's easier to handle. Put the paper from the new roll in the back slot, and hit "FEED" this will feed it through; after you have it through, roll up any lose paper, mount roll in holder, done, Should take about 3 minutes
    Mar 02, 2011 | Casio HR-100TMPlus Calculator
    Will not feed paper
    PAPER ROLL REPLACEMENT
    Never insert paper roll if torn. Doing so will cause paper to
    jam.
    Always cut leading edge with scissors first.
    1) Insert the leading edge of the paper roll into the opening.
    (Fig. 1)
    2) Turn the power on and feed the paper by pressing . (Fig.
    2)
    3) Lift the attached metal paper holder up and insert the paper
    roll to the paper holder. (Fig. 3)
    DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
    DAMAGE TO PRINTING MECHANISM.
    Dec 19, 2010 | Sharp EL-1801AII Calculator
    PRPH toilet paper holder. the fixture attached to the cabinet and supports the toilet paper holder has a broken post. The post goes into the toilet paper holder and supports it. During remodeling, I...
    Without more specific information or a product number difficult to assit; here is the website for the manufacturer where you can search for more information or find a parts supplier near you.
    http://www.robern.com/info/documentation.rbn
    Trust this is helpful.
    Oct 26, 2010 | Robern Prph Projects Toilet Paper Holder...
    Mar 25, 2010 | Office Equipment & Supplies
    Feb 13, 2008 | Canon P23-DH Calculator
    Sharp EL-2196BL
    Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
    1. Lift the paper holder up.
    2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
    3. Insert the paper roll from the left side of the paper holder and make sure the paper
    roll is set in the proper direction (with the paper feeding from the bottom).
    4. Insert the leading edge of the paper into the opening directly behind the print
    mechanism.
    5. Press the paper feed key and feed the paper under the edge of the paper cutter.
    Dec 07, 2007 | Sharp EL-2196BL Calculator
    19 people viewed this question
    k24674
    jasbo
    jasbo
