Question about GE Washing Machines
Won't rinse, won't spin, now not responding with start/pause button
It started with it not spinning the clothes so they would be sopping wet then it would stop mid cycle. We rebalance the load and just try again and cross our fingers. Now it is getting through the wash cycle and then will just sit there and count down. It will say rinsing and its not. It will say spinning and its not. I have rebalanced the load over and over again and even tried unplugging it to reset it and nothing is working. It is only 3 years old. It is GE model WHDVH626
Similar problem fixed in less than 5 minutes. Here's a post that was very helpful. http://www.foobert.com/blog/2007/04/02/ge-adora-front-loading-washer-does-not-drain/
There's a trap located under the front panel (3 screws) I undid the filter and pulled out 21 coins, 2 buttons, a 'letter h', zipper parts, a broach, and a whole lot of lint.
My wife said that the unit never got the clothes so dry afterwords, she said the almost didnt need to throw the clothes in the dryer.
NOTE: Have a ton of towels ready, and if you can fit a bucket or dish under the filter, go slow and steady. I opened it up and had several gallons all over the floor!
Posted on Jun 04, 2009
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Bosch washer won't spin with wet clothes
I am not sure if Bosch has a "load sensing" sensor, but I would start there else you may have a motor issue, or bad capacitor on your motor.
Aug 03, 2012 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Roper top load washing machine #8280871, worked well for a little while, now clothes are sopping wet and it will not spin or do anything after it rinses. Help, what part do I need to fix this?
If it is making noise when it is supposed to be spinning or agitating there is a coupling made of plastic with rubber flex joints on both sides replace this and should start working again 1195967 is the part # usually run 15-20 bucks
Nov 15, 2009 | Washing Machines
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
Kenmore 80 series washer clothes are still dripping wet
May 16, 2009 | Kenmore 24032\24036 Top Load Washer
Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Kenmore washer 24622300. clothes are very wet after spin cycle
washer may not be spining at all start in rinse cycle allow washer to wash and advance through cycle on it's own do not advance manually..after agitation listen for short pause after pause pump out should begin after pump out should be another short pause then spin should start..if spin does not start after 2nd pause suspect transmission if lid is raised spin may start but if it doesn't start during normal operation bad gearcase one other ck possible look underneath for oil it may be getting on clutch causing clutch to slip and not allow to spin full speed
Nov 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Water not draining out w/ spin cycle
sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
360 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
