Question about LG WM1814CW Front Load Washer
Washer wont turn on flashing de
Washer will allow me to select then when I hit start flashing in red de and dinging sound
  • LG Master
  • 3,361 Answers
Open the washer and clean the drain pump.
Posted on May 20, 2009
For the last few weeks, my 5 year old LG 2487HRMA, has been giving me de code errors shortly after starting. It is because the lock light just goes from red to off for no reason.
Lift up the top of your washer and there will be a code and test sheet in there that will help lead you to fixing that problem, almost sounds like it went into the its own test mode.
Jan 09, 2016 | LG WM2487H Front Load Washer
Wont start.buzzes.unplug to turn off
Possible unbalanced load in the washer. I have found this to be the case in other types of top load washers. Just redistribute the load the try again. If this works, washer is doing what it needs to do to keep from spinning madly out of control and extending its life!
Feb 25, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Wont start. I soaked a shower curtain in bleach, ran the machine to add water and then hit pause to allow the fabric to soak in the bleach before washing. I pushed the pause buttonn to continue thewash...
I would unplug the washer to reset it. if you have already hit the power button to turn the unit off and it failed to respond. Newer washer machines are like computers, and smart phones these days. you have to reboot them because they do sometimes lock up. Pull the cord for about 5 minutes and see if that resolves your issue.
Dec 03, 2013 | Maytag MAH6500 Neptune Front Loading...
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Will not start only ding ding sound
DING DING SOUND USALLY MEANS END OF CYCLE. MAY NEED TO ORDER MMC AN CHANGE THAT
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
FRONT BELLOWS
I have a whirlpool duet washer i can't retrieve the model number because the door is locked but the dryer which is the match to the washer is model number GEW9200LW. My question is that when I hit the control button then start, a muttled beep will sound not allowing the door to open. I get an error message of DL then it flashes to F? Any help?
May 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Please help , tell me why door is locked, on h 2 kenmore washer,
THANK YOU,
still nothing,
red doorlock light on, wont do anything,
I have to unplug so it will shut off,
when I plug in and hit start, red light stays on again,
Mar 28, 2008 | Kenmore 4292x Front Load Washer
Kenmore Elite HE4t Washer - "Control Locked"
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
Washer
Sounds like you need to replace the door switch
Jun 23, 2007 | Maytag MAH8700A Front Load Washer
LG WM1814CW Front Load Washer Logo
244 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
