Question about Maytag MSD2756G Side by Side Refrigerator
Icemaker don't work
I have a Maytag plus side by side/icemaker. My icemaker quit working, how do I fix it?
  • 2 more comments
  • Tracy Obrien May 19, 2009
    It is 10-15 years old and yes the wire is up. I don't think water is getting to it. It has made no ice at all in the last day, it was working.
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    How old is this unit? Is the bail (wire that detects ice) lifted up?
  • 585 Answers
The wire must be down in order for the icemaker to make ice. If it's up it thinks the hopper is full.
Posted on May 20, 2009
    Problem Solver:
  • 7 Answers
Most icemakers have their own brains so to speak all they need is power, low temp, and water to work.So check the water supply to the unit and use a test cord to check the water valve. It could be not cold enough in the freezer ,check temp and shrouds etc.
once you've ruled out outside influences you've got to dismantle the unit and check microswitches and stats all the while on the lookout for something thats broken lol
Maytag ice maker quit making ice
www.youtube.com/watch?v=oIHLyOn3Ht0
Check youtube.com for how to videos like the one above. Basically, if your icemaker is not refilling with water, your water valve may be faulty. Pretty much it's either that or a blocked/clogged filter, or the icemaker itself. There are plenty of websites to get replacement parts at a reasonable price. Neither the icemaker or water valve are that difficult to replace.
Jul 28, 2014 | Maytag MSD2756G Side by Side Refrigerator
Have a Maytag side by side with ice maker...it quit making ice within 3 months of installation. Had one repair man look at it...said that it was a common problem w/ Maytag...hit ice maker with his fist a...
Assuming it's not still under warranty, I would probably replace the icemaker components inside the freezer.
The repairman's "fix" indicates that there is some kind of problem with the "brains" of the icemaker. It would probably not be cost effective to try to diagnose and fix the problem.
Oct 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool IceMagic Plus not working.
Pour about 2/3 cup of water into the ice maker . If it dumps the ice but doesn't refill , replace the ice maker . If it doesn't dump , and the cubes stay in the ice maker , replace the ice maker .
The switch on the icemaker for normal , runs the icemaker normaly . In the ice plus , a small fan comes on , blowing the inside air , over the ice maker mold , to help it freeze faster .
Sep 14, 2009 | Refrigerators
Water dispenser doesn't work
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Ice maker does not work
Aug 11, 2009 | Maytag MFD2560HES Bottom Freezer French...
Icemaker quit working after I cleaned the coils.
After checking the fill tube (line that fills the icemaker) to make sure it's not frozen , pour about 3/4 cup of water into the icemaker . If the icemaker dumps the water but doesn't refill , replace the water inlet valve . If the icemaker doesn't dump the ice , replace the icemaker . ALSO , make sure the fan which cools the compressor is working . Possible when cleaning the coils , a glob of lint or something , was sucked into the fan and blocked the blade from turning .
Aug 04, 2009 | Whirlpool ED5FTGX Side by Side...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Icemaker not filling with water
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 01, 2009 | Maytag MZD2669KE Side by Side Refrigerator
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag MS2732GRW ice maker quit
guest make sure your wire arm on icemaker is down same dandcs also for orig poster they have duel water valves one goes to door water one goes to icemaker. icemaker works a general rule more than door water so wears out faster but you have to replace both as they are a unit .other things that will stop ice production are frozen ice fill tube ,bad motor module in icemaker .check that first .if that don't solve it then reply to me and we will get deeper
Dec 31, 2007 | Maytag MSD2732GR Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
258 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
