Question about Coby MID8065-8 - Kyros MID8065 8 8 GB Tablet - Wi-Fi - ARM
Coby mid 8065 stuck on initial coby screen
Tablet will not boot just gets stuck on Coby screen. I have tried reset button as well as pressing power and lower volume buttons together trying to get to factory reset screen but, no luck.
reyjoshua07
  • 1157 Answers
SOURCE: my coby tablet won't open
Hi s112ronnie,
If your Coby tablet suddenly has no response or powers off, an elec-trostatic discharge may be the cause. In this circumstance, please follow these procedures for recovery:
1.Reset the player (use a paper clip to gently press the Reset button (on the bottom of the player).
2.Turn on the unit again
NOTE: Back up your data to an external source prior to performing reset.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 17, 2011
  • 11 Answers
SOURCE: coby mid 1125 wont boot up
did you buy it from a reliable source? lots of bad tabs and "pads" being sold online lately. might be bad internal power source. suggest take it to local dealer and let them troubleshoot, take the advice then fix yourself if you are good with electronics, or let them fix it or trade it in.
Posted on Dec 20, 2011
jmernst
SOURCE: my coby kyros mid 1125 want unlock when i try to slide the unlock slider nothing i've tried to power down it want let me do nothing help please!!!!
Have you tried taking the battery out? That solves a lot of problems.
Posted on Dec 27, 2011
  • 4961 Answers
SOURCE: My Coby Kyros MIDI 1125 tablet is passworded.how can I bypass that to reset it?
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" image002.jpg till the "Device Option menu image003.jpgappears.
Step 2- Click on "Power Off image004.jpg and select "OK" image005.jpg.
Step 3- Once the unit has been turned off. Press and hold the "reset" image006.jpgbutton and "power" image008.jpg button simultaneously for eight seconds.
Step 4- The following screen image009.jpg will appear. Press the "reset" image006.jpgbutton.
Step 5- The Android system recovery screen image010.jpg will appear.
Step 6- The "Home and Menu" image011.jpg button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". image012.jpg . Press the "reset" image006.jpgbutton.
Step 8- The following screen will appear. image013.jpg.
Step 9- Press the Menu" image014.jpg button to select "Yes- delete all user data".
Step 10- Press the "reset" image006.jpgbutton.
Step 11- The following screen will appear image015.jpg.
Step 12- Press the "reset" image006.jpgbutton to reboot/restart the unit.
Posted on Aug 19, 2012
  • 7 Answers
SOURCE: can not unlock my coby tablet
it seems like that your tablet's touchscreen panel has a defect, to get the full functionality of the touchscreen panel it should be replaced...
Posted on Sep 04, 2012
Why my coby mid8065 stop working i try the reset button but still nothing happen, it show the coby logo and the android but didn't go far.
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
Sep 08, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
My Coby Kyros mid 7048 is frozen on android? How do you fix that problem?
Sep 02, 2014 | Coby Kyros 7" Touchscreen Tablet
Coby not working
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
May 28, 2014 | Coby Tablets & eReaders
Coby mid7048 won't boot past Android screen and won't turn off
Press and hold the power button for about 20 seconds. It should hard reset. If it still get stuck. Power it off. Press the power button then press and hold the power + silver back button for about 8 seconds. You should get a menu that will allow you to factory reset the tablet.
Dec 08, 2013 | Coby Kyros MID7048 7" 4 GB Slate Tablet -...
Coby kyros MID 7022 wont unlock main screen....swiping only meets halfway then screen goes black..help?
ok try the reset button plug the power cord before you start. look where is the reset and use a small point toothpick .
Nov 03, 2013 | Coby Kyros 7" Touchscreen Tablet
My tablet wont turn on it continues to blink but wont turn on
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work:
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 20, 2013 | Coby kyros Tablets & eReaders
Coby kyros mid 7022 is stuck on lock scteen, how do I get around this? Also goes into hibernate for seemingly no reason. Very new android user, no clue what I'm doing
Here is the instruction on how to do the factory data reset when a customer locks the system and lost his security password/pattern. This instruction works for MID7016 and MID7022. An end user must follow each step precisely. Otherwise, he/she will not access to the system menu mode.
  • Connect the AC power adapter.
  • Turn on the system.
  • Press and hold the power button until the popup window of "Device options" appears on the screen.
  • Select the "Power off" option from the popup window. You will see another popup window of "Power off".
  • Select the "OK" option. The unit will turn off.
  • While holding down the "BACK" button, press and hold the "POWER" button until Coby logo appears on the screen.
  • Release both buttons once you see Coby logo on the screen and wait for a while. The Coby logo screen will change to Android logo.
  • Wait about 15 seconds after you see Android logo. (Do not press any button while waiting. If you do, you will not be able to access to the system menu.)
  • Press the "BACK" button once. The system menu screen will appear on the screen.
  • Choose the "wipe data/factory reset" by using the "HOME" and "MENU" buttons. (The "MENU" button will allow you to browse down through the option list, while the "HOME" button will allow you to browse up through the list.)
  • Press the "BACK" button once you select the "wipe data/factory reset" option. The confirmation message will appear on the screen with YES or NO option.
  • Choose the "Yes - delete all user data" option by using the "HOME" and "MENU" buttons.
  • Press the "BACK" button once the "Yes - delete all user data" option is selected. It will perform the factory data reset. Wait until it is done. Once it is done, the main system menu will appear on the screen again, and the "reboot system now" option will be selected as a default. If not, you will need to select the "reboot system now" option from the list.
  • Press the "BACK" button to reboot the system. The system will reboot with the initial factory data setting. All user data will be lost.
Give the reboot at least 5 minutes. Do not assume the unit has frozen
Sep 02, 2011 | Coby Kyros Tablet
Coby MID8065-8 - Kyros MID8065 8 8 GB Tablet - Wi-Fi - ARM Logo
46 people viewed this question
Top Coby Tablets & eReaders Experts
Martin Murray
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
