Question about Insignia IS-LCDTV32 32 in. Television
No Audio on Insigna Moddel NS-LCD37
No audio from Speakers or Earphone.
  • jerrygoode May 22, 2009
    That is not the Problem.
    Will not work with External apmlified speakers either.
    Also can not get Video or audio using Composite input.
    Only get video using tuner.
    Trying to determine if problem on main board or Power supply board.
  • jerrygoode May 23, 2009
    No I have isolated it to Main Board issue.
    President:
  • 1,383 Answers
Go to menu and reset all settigns to factory defualts.
Then check your speker connection to bord.
Posted on May 23, 2009
  • 355 Answers
Pull the power plug from the cable box and the wall and let it sit a couple of minutes. Then plug it back in and let it reboot. Don't power up the TV yet. The cable box should reboot and reset it's settings. Once the time shows up on the display, then power up your TV so the cable box can recognize the TV. It this doesn't work, you can always bring the cable box by the cable office and they will replace the box.
Posted on May 22, 2009
  • Rohit  Asthana
    Rohit Asthana May 22, 2009
    sound problem only happen when you hook up a cable box like direct tv or something. or in general will you lack sound until you manually reprogram in via remote.
    or try this
    Top Expert:
  • Insignia Master
  • 79,847 Answers
Have u gone to the set up menu and checked to see if the tv's internal Speaker's some how got switched off? it happens. Select TV menu, then audio/visual set up then look for speaker options.
Posted on May 21, 2009
I have insignia ns-lcd37 no sound at all. Not thru tbe speakers, rca plugs, headphone jack, nothing.
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Dec 24, 2016 | Insignia Televison & Video
No audio driver installed
Never heard of insignia but the obvious answer would surely be go to there ebsite look for a drivers section and then download the driver that fits the description of yoour moddel of speakers and install you may nneed to restart computer
Apr 15, 2014 | Insignia Audio Players & Recorders
NS-lcd37-09 firmware update
Check this link. http://electronicshelponline.blogspot.com/ It has details about the firmware update to many brand TVs, with screen shots. Pull up previous posts there, either by its left side bar, or view it in Timslide option. Firmware update process to Insigna models are there.
Jun 28, 2013 | Insignia Televison & Video
Left earphone broken
Bad headphones/speakers
It's unlikely your headphones or speakers are bad, but it's worthwhile to eliminate these as the source of your problem at the beginning. Try your iPhone with another set of headphones or speakers just to make sure that the problem is with the iPhone.
Bad audio jack
The most likely cause of audio output problems on iPhone 4S is a bad audio-out jack. If you have determined that the problem does not lie in your external speakers, you should replace the headphone jack.
please follow the steps and fix it.
God bless you
May 28, 2013 | Cell Phones
I have a insignia ns-lcd37-09 tv.The screen suddenly turned green.I can here sound but no picture.can you help?
Change input device to some other which you know works for sure. If problem persists, try changing the channel. If you notice same problem, this may need attention by a qualified service technician.
Jul 21, 2012 | Insignia NS-LCD37 37 in. LCD TV
No audio with cable no video with dvd
Hi, Pull out the plug for 1 hour. This will reset to default. If this does not fix see your local repair man. Good luck.
Aug 04, 2011 | Insignia NS-LCD37 37 in. LCD TV
Audio crackle from any hdmi device plugged in to EITHER HDMI port
Hi, Sounds like bad HDMI cables. I've had this issue myself and you look at the cable and you can't see anything wrong with it but there is internally. My suggestion is to get a new HDMI cable.
May 12, 2011 | Insignia NS-LCD37 37 in. LCD TV
Is there a usb connection
There's a manual in pdf format for the NS-DV2G on this page:
http://insigniaproducts.com/cms/documents/NS-DV2G%20UM%20EN_SP_FR.pdf
There's a mini USB port near the earphone plugin: viewing the display and the scroll wheel on the right, the mini USB is on the right side.
All support for this player can be reached here:
http://insigniaproducts.com/products/portable-audio/NS-DV2G.html
Jul 20, 2010 | Insignia NS-DV2G MP3 Player
I have a ns-lcd37 tv it's has nice picrure but no sound can u help me it's a insignia
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Nov 19, 2009 | Insignia 37" LCD Flat-Panel HDTV
Insignia NS-LCD37 TV - no sound
Start checking the cable connection to receiver, try moving or replacing cables.
If you have a surround with external speakers check surround connection cable and speakers wiring.
If the cables are OK, then the unit may be faulty.
In that case the fault can be either the audio board (often audio circuit is integrated on the main board) , or the sinput output signal board.
Also a contact on connection to internal speakers can give you same problem.
May 22, 2009 | Insignia NS-LCD37 37 in. LCD TV
Insignia IS-LCDTV32 32 in. Television Logo
124 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
