Question about Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350
Trouble getting it to turn on
Takes numerous pushings of reset button before it will finally turn on
My cannon scanner MP240 is getting an error E5 please help to find out the solution
Error ink cartridges are not installed properly (Error E5)
First power off the printer. Next, while holding STOP/RESET button, power on the printer.
While holding POWER button, release STOP/RESET button. Then push STOP/RESET button twice.
Wait about 20-30 second until the LED shows "0?. Then push STOP/RESET button four times.
Finally push POWER button twice. Last step is to turn off the printer by pressing the POWER button one last time.
Jul 07, 2011 | Canon PIXMA MP240 All-In-One InkJet...
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
Ip 1700 absober tank almost full
For now, you can resume printing by pressing Resume/Cancel. Eventually the message will change to absorber is full and stop printing. In some cases, you may need to reset the printer by 1) turn the printer off, 2) disconnect the data cable if using a wired connection, 3) unplug the printer for at least 10 minutes (unplugging the wire from the outlet may help) then plug it back in. Check if the error persists before connecting the data cable.
To solve the problem, you need to remove the waste ink absorbers and either clean or replace them and then reset the counter. The absorbers are two sets of pads inside the printer. One set is under where the printhead cleaning cycle occurs. The other is at the bottom of the printer; you need to disassemble the printer from the top, removing several screws. If you attempt this procedure, have lots of newspaper or other absorbant material around. This will get messy. Get the pads out of the unit (taking pictures will help you reassemble the printer). Then blot off the excess ink from the pads and the area where the pads are positioned. Then put the pads under running water until the water remains clear. Wait for the pads to dry (a blow dryer can speed the process up). Reassemble the printer.
Now reset the counter. (Do not do this step without cleaning the pads, eventually ink will get everywhere inside your printer and out.)
First try:
If this fails, try:
Unplug power and USB cable.
Open door and hold power button.
Connect power.
Close door, then release power button.
Final reset option for an IP1700 is:
Turn Off the printer, and then take off the cable power.
Push and hold the power button
Connect again the power cable.
Use your middle finger to push the resume button 2 times.
Release the power button.
Please note that the counter is programmed for a value that should be reached when the printer is nearing the end-of-life for the unit. If the printer is under warranty, let Canon fix the problem. If it is out of warranty, you may find other parts of the printer failing soon.
I hope this helps.
Apr 18, 2011 | Canon PIXMA iP1700 InkJet Photo Printer
The timer flashes, "no-op". Refuses to turn
no-op means 'no operation.
The manual says last resort to revive non-working timer is RESET timer.
This action will delete current day setting and all programming
Hold down ON/OFF and use paper clip to push in reset button for 2 seconds.
Release reset button but keep holding ON/OFF button down until INIT flashes on screen
Then release ON/OFF button and 12:00 should display.
At this point, timer can be re-programmed.
Simple step by step shows on following link:
http://waterheatertimer.org/ST01C-program.html
If timer will not accept programs, or operate after RESET, then timer has gone bad.
ST01C comes with 1 year limited warranty.
Most in-wall timers have same limited warranty.
Replacing timer:
-Advantage of ST01C is timer does not need Neutral wire to operate, and wiring can be simple.
-If you are using ST01C for 3-way switching, then easiest thing is to replace with same timer.
-If you are using timer as astronomic dawn-dusk, then replacements include EJ500, Utilitec 0192773, Aube T1034, T1070, T1072, T1073.
-If you are using timer for 7-day operations then there are numerous options:
http://waterheatertimer.org/Programmable.html#Aube
Jan 08, 2011 | Intermatic Inc. ST01C Digital In-Wall...
My hp 3310 wireless printer freezes and displays a blue screen (on the printer) with alpha numeric characters
Hi
Try resetting the printer
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks
Riz
Dec 29, 2008 | HP Photosmart 3310 Printer
Lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Sep 25, 2008 | Ovens
Power slow start/bulb light
Did you get the exact replacement lamp? Some have 1.1 arc gap some have 1.3 they wont interchange. If you got the exact lamp and your trouble is still the same. It could possibly be your ballst.
Jan 16, 2008 | Televison & Video
No fm reception
We had trouble switching from AM to FM. We finally solved the problem by pushing the reset button on the back of the unit (any sharp pointed object can be used to engage the reset button). Do this followed by setting the mode to FM and try tuning in your FM stations. Try the procedure several times and it may finally kick in, as was the case with us getting our AM stations
Dec 30, 2007 | GPX HM3817DT Shelf System
Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350 Logo
234 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
