Question about Kwikset Locks & Locksmithing
Kwikset thumb plate on handleset is loose and won't work
    Problem Solver:
  • 26 Answers
Remove outer trim, tighten inner trim, put outer trim back. Go to Kwikset.com for full installation instructions for your model.
Posted on Dec 04, 2014
4 Suggested Answers
  • 10 Answers
SOURCE: Lost entry door key, need to rekey kwikset deadbolt
Unfortunatley you need to have the key to remove the cylinder. You can take it to a locksmith that can pick" it to remove the cylinder and make you a key but it may be more cost effective to replace it.
Sorry not to be mre help.
Posted on May 22, 2009
rsmith972278
  • 160 Answers
SOURCE: I need extra keys for my Kwikset handleset. Had
The problem you are having has nothing to do with your lock. Modern key cutting machines are so automated that they do a very poor job in key duplication. I suggest that you find an old hardware store that has an older key machine. Or possibly, it might be cheaper to simply replace the lock set. A new Kwikset keyed entry sells for about $40.00 for a lever handle. Remember to have extra keys cut at the store when you purchase the lock...so you can check the duplicates in the store. I do this at Home Depot regularly. They have a new machine, but with the lock right there, they can manage to cut some duplicates after a few bad ones.
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE ME
Posted on Nov 24, 2009
  • 101 Answers
SOURCE: How do I reassemble the latch mechanism of a kwikset 510 handle set?
http://s7d5.scene7.com/is/content/BDHHI/5048328
This might be helpful
Posted on Aug 07, 2014
Install a single handleset
Is this into an existing door or a new door. Is there existing cut outs where the lock set goes or is this a blank door?
Jan 21, 2013 | Kwikset Ultramax Security - Shelburne"...
How do I change from LEFT opening to RIGHT opening for the Arlington Lido handle set single cylinder
This web page will take you to the General description of your model:
http://www.kwikset.com/Products/Details/Handlesets/802AN-LIP-L03.aspx
I suspect that this special-order lockset may not be reversible-in other words- specific to right-hand or left hand only.
I therefore urge you to contact Kwikset directly for further assistance. Click on the link found on that page for Customer Support, then "Contact Us"
Any further model information and description that you can provide will be helpful.
Jul 29, 2011 | Locks & Locksmithing
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
Kikset dead bolt is loose on front door from the outside...
there should be a small allen screw on the shaft of the thumb turn on the inside. loosen the allen screw, pull off the inside thumb turn and take a small flat blade screwdriver and gently pry on the edge of the cover. It will come off. the 2 screws are under the cover plate. If this helps, lt others know. thanks
May 31, 2009 | Kwikset Professional Door Lock...
May 21, 2009 | Kwikset Professional Door Lock...
Kwikset arlington handleset needs to be tightned
Look at the most bottom part of the hardware on the inside and see if there is a little round decrotive cover [looks like a button,dime size] and will either will pop off or try unscrewing,once of you should find a single screw which will allow you to tighten hardware or remove.
Please rate.
Mar 14, 2009 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Loose Kwikset Chelsea Deadbolt
I just had the same problem as samrpetrich with a loose kwikset deadbolt. Here's how I fixed it - on the inside of the door, take off the latch that flips the deadbolt in and out using a very small allen key. There is a round plate cover that is snapped on top of the inside deadbolt mechanism. If you look on the bottom aspect of this round plate you'll see where it snaps on; once I saw where to apply pressure it came off easily - taking off this plate exposed the two screws beneath that were loose. Once I tightened these, I snapped the plate cover back on, but the dead bolt latch back and everything is tight again. Hope this helps.
Jan 23, 2009 | Kwikset Professional Door Lock...
Kwikset deadbolt
use the proper size alan wrench to tighten or loosen face plate . That is if you have not stripped that hole by putting the wrong tool to it. Under that plate is the 2 main screws to hold the hardware tight to the door.
Oct 27, 2008 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
503 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
Steve Masymas
Level 1 Expert
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
