Question about Sharp LC-60LE600U 60" LCD LED TV 1080P
Tv won't come on i think it blew a fuse--Help?
Panasonic TH37PX80B tv won t turn on
Probable power supply failure.
Apr 02, 2014 | Televison & Video
When we plugged the a charger in the cigarette lighter it sparked and now the radio won't turn on, even to enter the code. I think we blew a fuse, but I can't figure out which one as I thought it...
have you checked both fuse boxes? there is one that is under the hood. if there is a radio fuse right there, it will most likely also say backup. there is also another fuse box by the drivers right knee which also has a radio fuse. hope this helps, goodluck.
Jun 01, 2011 | 2003 Honda Pilot
Blown fuse on panasonic tv
Maybe the horizontal output IC are on short circuit.
Nov 04, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
32'' Panasonic TV, 4 yrs old, keeps blowing the fuse
Hi Mendi.
I had a similar problem, in that I could not find the proper fuse for my set. I bought a bit higher amp fuse from Radio Shack and it ended up blowing a couple months later. I've since pulled the TV down and replaced it with an LCD set, so I've solved my problem.
But, to address yours, I don't think the amp difference would not be the problem. Likely, there is a power issue on your set causing it to draw more amps and become out of specification. Using a higher amp fuse would buy you more 'capacity', but if its blowing those too (repeatedly), its likely a real problem in the set. I'm not a TV technician, so I can't tell you why. I'd suggest taking the thing in for service (cheaper than the house call) or if that is too expensive, looking at putting your money into a set that won't give you those problems. Or, just keep replacing the fuse until it doesn't fix the problem.
Sorry I cant help much more.
May 13, 2008 | Panasonic CT-36SL13 32" TV
Will not turn on.
If the TV is blowing the fuse in your house, It looks like a component in the power supply is shorted.
To fix the TV, you will need to buy a new power supply module or get the one inside the TV fixed.
Good Luck.
Apr 24, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Power
That 6.3 amp fuse IS the main AC fuse. I thought you were going to take the board out and send it to ptscorp for an overhaul?
Feb 09, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Power supply
I thought you were going to take out the power supply board and send it out for an overhaul?
Sony KP-65xrb10w. (65
Dang, How many times are you going to post? You only need to do it once.
Sharp LC-60LE600U 60" LCD LED TV 1080P Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
