Question about Frigidaire ATF6000ES Front Load Washer
Water remains under rubber seal. Water too high in bleach dispen.
I have a three-year old front loading Frigidaire washing machine, I really like it. But, the water level seems too high in the bleach dispenser. It is at the "low" level line for the bleach. Also, water remains under the rubber seal around the door. I worry about mold, etc. forming in this area. Is there anything I can do about either problem?
Did you try taking the dispenser tray apart and cleaning it? The exit ports tend to clog over time. Best thing I have found is to remove the tray at the end of wash day, rinse it out, dry it and put it only partially in the machine, thereby allowing air circulation. Some water will always remain at the end of the wash cycle...inherent in the design.
As for the gasket, you'll have to wipe it down at the end of wash day and leave the door open to dry everything out. I leave mine open all the time.
Posted on May 20, 2009
Smell from water remaining in grey seal
My GE washer model wcvh6400j0ww was leaking. May be standing water under your machine. The repair person thought the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 13, 2010 | GE Energy Star WCVH6260F Front Load Washer
Water remains in tub after spin cycle
Have you tried to clean the drain hose on the back of the washer? It may have build up inside that you are loosening up by using bleach.
Sep 06, 2009 | Frigidaire ATF6000ES Front Load Washer
I have mold on the rubber door seal
This is a comon problem In areas where miosture is high and the tempiture is warm. Try using bleach to clen it off with or you can use super clean to remove it from the rubber. Not touchingthe seal with your hands and clothes will help some to.
Aug 31, 2009 | LG WM-2277HW Front Load Washer
LG TROMM WM2496HSM MILDEW & MUST SMELL
I have had the same problem with mine. I have started taking the rubber seal off at least once a month to clean it with bleach and water. I would not recommend doing this unless you are handy with tools. You might try cleaning the seal with bleach and water while it remains on the machine. Careful to pull the inner sealing lip down to get to the "Slime" behind it. Good Luck
Jul 26, 2009 | LG WM-2277HW Front Load Washer
How do I get rid of the musty smell?
If you know someone who owns a bar, ask them for about 1/2 pt of line cleaning fluid. Start your machine on a 60o wash (empty) and as soon as the water starts flowing into the powder drawer, slowly pour the line cleaner into the water flow. Let the machine go through it's normal cycle, then run the same cycle programme as soon as you can (immediatly if possible) using clean water. Following this action, get your finger and rub it along the inside of the drum, if it's squeekly clean it's solved, if it feels slightly slimely, run the water only wash again the completly to remove any further residue of the cleaner. The smell should go. Let me know how you get on, Regards Dave.
Jul 17, 2009 | Frigidaire Affinity ATF6000F Front Load...
Musty smell in washer and clothes.water remains in rubber gasket
Two thing that you might try: Add two or three cups of bleach and have the machine run a cycle (with no clothes!!!). Second, always leave the door open after use to let it air out. Also, it wouldn't hurt to use straight bleach as a wipe to the entire rubber tub seal.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
FRONT TUB SEAL HOLDING WATER
no fix ..ALL BRANDS have same issue just ck out other web sites best solution ..leave door open as much as possible ..clean out boot with bleach/water solution at least once a month..CHLORINE BLEACH!! and no not the answer you wanted but best answer you'll get and that from experience
Nov 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Black mold growing on rubber gasket and under rubber gasket in Whirlpool Duet front loading Washer
The solution? Plain old bleach.
Scrub rubber seal on door. Run the bleach through the machine once a month to keep clean.
Keep door open after each wash to ensure that it dries out properly.
d
Oct 12, 2008 | Whirlpool Washing Machines
Smell
this is a common problem with all front loaders. you need to manually clean the boot, rubber seal, with bleach and water but when done with that you need to put 1 1/2 cups of bleach in the soap dispeners, run a hot wash with no clothes after that run another rinse to be sure all the bleach is out of washer. inbetween washes, leave washer door open (best) or cracked if no room to leave it open
Nov 20, 2007 | Frigidaire ATF6000ES Front Load Washer
Bosch Axxis Front Load Washer
This video will show you how to change a door seal on this Bosch GLTF2940ES front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Aug 20, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
149 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
