Question about Hitachi Director's Series 65XWX20B 65" Rear Projection Television
How long does a Hitachi 42" rear projection tv last?
  • 18 Answers
SOURCE: hitachi 53fdx20b rear projection color tv with no picture
Reset tv to factory settings refer to your owners manual. If still no picture attach a DVD or video player and test. If still no pic refer to tech.
Posted on Jan 05, 2008
ctf1800
  • 4402 Answers
SOURCE: cleaning tv screen of hitachi rear projection tv
http://serviceman.site88.net/index.htm
Posted on Jul 07, 2008
freetek
  • 5568 Answers
SOURCE: Hitachi 53" rear projection is losing its picture.
If you are not experiencing any shift in colors, it sounds like the power supply is failing since this will affect all three colors.
Posted on Feb 28, 2009
  • 668 Answers
SOURCE: cant attain digital channel scan on hitachi rear projection tv
Do you have the tuner locked out for use of HDMI input only?
Most of the time when a selection is not able to be hi-lited it is
because a feature that is activated locks out other selections.
Hope this helps,
Skyassoc
Posted on Jun 17, 2009
SD Tech
  • 14553 Answers
SOURCE: hitachi 51f500a rear projection tv screen looks 3d
This model uses two convergence IC's----if 3 D one or both are bad.
Most of the time this set uses either two of the STK-392-110 OR THE STK-392-150 CHIPS.
Both chips and any bad protection resistors around them need to be replaced and the set adjusted.
If you are able to do the repair yourself total parts cost will be under 30 dollars.
Some history for you:
This set like all rear projection tube type sets uses two chips---the ones in your set are Black in color--about 2 1/2 inches wide X 1 1/2 inches tall and are on either one large or two smaller heat sinks with fins on them.
When the chips are installed a white grease called heat sink compound is applied to the metal back of each---the grease transfers heat from the chip quickly to the metal it is bolted to.
After some years the grease dries out from the heat and one of the chips goes instantly.
You can buy a pair of the chips for your set on Ebay for less than 15 dollars plus shipping--
If you cannot do the repair yourself--shop around your area---most shops charge 300-400 for this type of repair. Whoever you get to do it make sure BOTH chips are replaced or you will have the same problem in a few months.
If you open the set and locate the chips---they will have the full STK number printed on them in white letters----there are about 12 resistors around them that need to be looked at--if any are discolored they need to be replaced.
If a shop says it HAS TO GO TO THE SHOP keep looking as any good tech can do this repair right in your home in about 1 hour---I know as I have done hundreds of them.
IF you can solder and are handy I will give you general instructions on how to do the repair and what you need---some people I talk to can either do it or have a friend who can do it for them---let me know
I can tell you what you will need aside from the parts and how to proceed with the fix---
If all this helped rate this solution---I do this here for free.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE LET ME KNOW--I am here to help people.
Regards, SD TECH
Posted on Oct 30, 2009
Testimonial: "You truly are an expert! Thanks for the advice, don't think it could've been explained any better!"
My lamp light on my 42" rear projection.
you need to replace the lamp you will need to know the model# you can find it on the back of the tv
Jan 26, 2010 | Hitachi 43UWX10B 43" Rear Projection...
How long do the bulbs last
Hello Dingbo the bulb usually last anywhere from 3-5 years on rear projection tv sets, every bulb is different in specs, but they usually have like 5,000 hours or so of working time. Now Ding from my experience i have seen rear projection tv sets last up to 15 years, Thank You hope this helps.
Sep 07, 2009 | Hitachi 57F500 57" Rear Projection...
42 inch hitachi plasma
the more the tv remains on the picture gets out of focus mainly in the midle of screen. Sure sounds like tv needs some light engine repair or replacement.
Aug 11, 2009 | Hitachi 60V500 60" Rear Projection...
Black line on hitachi projection tv
sounds like the water has went under the rim and dried there the line will never disapear
Jul 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Dark yellow halo on screen
I believe you have a optical Engine causing the problem. Due to the cost, I would call Hitachi to see if they could help with repairs.
Hope this helps,
Skyassoc
Jul 04, 2009 | Hitachi 42V710 42" Rear Projection HDTV
52" hitachi projection tv 98? convergence problem
Tell me more about the convergance problem. Are the colors all seperated? Did this happen all at once??? Give me a call at my shop and I'll talk to you direct on the problem. 307-266-4675 Mon-Fri 9-3 MST.
Ed
Jul 28, 2008 | Hitachi 42V710 42" Rear Projection HDTV
Moving of a TV
I would not, because you have fluid on the crt's and it could leak on the boards causing a short. But it's a chance you can take.
Dec 25, 2007 | Hitachi 42V710 42" Rear Projection HDTV
Hitachi Director's Series 65XWX20B 65" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
