Question about Goodman Heating & Cooling
Evaporated coil in goodman a/c arpto32-ooc-1a needs replacing...?? How much would it cost... the coil is under warranty but my a/c company says it will be $640 to replace does this sound right??
  • 3,361 Answers
I charge $350.
Posted on May 20, 2009
Puron leak
not all electronic leak detectors pick up r410a-puron. Evaporator coils are notorious for leaking puron. your coil should be under warranty.
Sep 20, 2013 | Goodman CKL42AR42 Air Conditioner
I need to find out the warranty on a AC unit Model # CKJ30-1A Serial # 0107449294
Warranty is a five year parts only from date of installation, based on the information you provided it was manufacture in 2007 which indicates it is still under parts warranty until Jan, 2012
Aug 22, 2011 | Goodman Heating & Cooling
I have an aruf036-00a-1a and have been told the evaporator coil is leaking. The unit is approximately 7 years old. Do I need to buy the whole box with blower and all or can I just purchase the evaporator...
The evaporator coil can be purchased separately and is the most common part to leak on an a/c system. The system must be evacuated of refrigerant and the old coil cut out and the new installed. Leak check performed and vacuum pulled on the system before recharging with refrigerant.
Jun 26, 2011 | Goodman Heating & Cooling
I have a coil that needs to be replaced on a 2002 Goodman heat pump system. I know it's still under warranty, but the previous home owner didn't write the serial number down and the contractor says the...
give the dealer the cond. number and they can find the invoice for it and hopefully the evaporator was sold with it on the same invoice. Sometimes there is a number inside the indoor coil on a sticker
Sep 07, 2010 | Heating & Cooling
John. Heidel@MSSB.com I have 2 carrier units both installed in 2006 and still under warranty, they are a 38brc030 and 38brc042 the evaporator coil in both units have to be replaced and the compressor coil...
The best thing to do is to call Carriers customer service line or their tech. support number... often times the customer talking to the co. directly will get better results then the dealer talking to them...
The dealer does need to recover thier costs also... they do not make that much money on the initial installation...
It is worth a phone call or two for you to call the factory and tell them how you are going to tell all of your friends NEVER to buy any carrier products because they do not stannd behind them!!!
heatman101
Aug 19, 2010 | Carrier 38BRC036 Air Conditioner
The freeon in my air conditioner has leaked out. i need to know if my air conditioner is under warrenty
your going to need the unit serial number and you will need to contact either a local Goodman distributor/dealer, or you will need to contact the installing contractor.
Depending on the age, most Goodman units come with up to a 10year warranty on the coils from defect. But that all depends on the model and age of the unit. Older units were only subject to a 5 year warranty on coils.
Regardless, the warranty after the first year will only cover the cost of the coil itself. You as the homeowner will still be responsible for the removal of the old refrigerant, labor to remove and install new coil, new filter drier, a proper pressure test, evacuation, and recharge of the unit. Its still a pretty penny but hey, at least the coil would be covered.
You will need to get up with a local contractor. Check around. Some contractors will not due warranty work either because of permission reasons, liability reasons, or other reasons that cannot be explained by anyone but that contractor.
Jun 03, 2010 | Goodman PHKJ048-1 Air Conditioner
Evaporator coil needs to be replace again. Installed w new manufactured home; 09/2005. Replaced 05/30/08. Needs to be replaced again 09/17/09. All due to leaks. Freon was added. Currently has small leak;...
the manufacture is only required to supply the part free of charge thru its warranty period. the installing company probably would only give a 1year labor warranty and honor the pparts thru the manufacture for 5 years but unless you paid additinal for an extended labor warranty i dont think you are going to have much luck. Make sure you change your air filters every 30 days a dirty filter is one of the biggest causes of evap coils prematurely leaking. Sorry wish i could be more help.
Sep 17, 2009 | Intertherm P3RA-042K Air Conditioner
Sudden loss of refrigeration
why does it need to be replaced but in south afrika it costs r400.00 and labour r400.00 total cost r 800.00 but what is the problem maybe i can assist
Jun 17, 2009 | Sub-Zero 690 Side by Side Refrigerator
Evaporator Coil
Yes, just count how many pins per inch and replace with the same number of pins per inch.
Sep 09, 2008 | Heating & Cooling
Heating & Cooling Logo
249 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
