Question about Dell Dimension 3000 PC Desktop
Won't boot yea my 3000 won't boot i'm fixing it for a friend i start it up it wont boo it says primary drive 0 not found below that its says Alert! os install mode enabled.Amount of available memory limited to 256 mb strike the f1 key to continue, f2 to run the setup utility at first i thought it was hard drive problem so i replaced it and i still get the same error please help i despertly need it
  • phil24980 Nov 14, 2007
    i have a similar prob my com wont boot it says the following :
    primary drive 1 not found
    secondary drive 0 not found
    secondary drive 1 not found
    strike the f1 key to continue, f2 to run the setup utility.
    if i stike f1 key the com says windows starting etc. only thing that happens is the dell desktop picture appears, no desktop icons or start menu. It also wont allow me to open the cd drive at any time, so i cant re-install with the windows xp cd. any ideas any help would be greatly appreciated thanks
  • 1,006 Answers
First go to the BIOS load optimal default or load setup default and restart the pc.If it wont work so go to BIOS AGAIN and make primary master HDD 0!
If still wont work so just repair with original winxp cd
Gooood LUCK
Posted on Oct 19, 2007
    Scholar:
  • 110 Answers
Just reformat, see if that helps.
Posted on Oct 18, 2007
My PC won't start,I get DISC READ ERROR
If you can boot from a boo-table CD then you hard disk drive has a problem. To boot from a CD disk, power onyour computer and tap the key to bring you to the "One time bootmenu". Insert the CD into the top CD/DVD drive and then select "Boot fromCD/DVD" and hit key. Select the "Run the 32 Bit DellDiagnostics.
If all tests pass then reload OS ( Operating Software ).
Jul 04, 2011 | Dell OptiPlex GX270 PC Desktop
Trying to install windows 7 retail 64 bit on Scorpio (was installed once already started getting wonky so decided to format reinstall) boot with usb dvd rom drive get to unpacking of windows files and...
According to Microsoft, Windows 7 must be installed on a primary partition. This error code means the installer hasn't found a primary partition on the target drive. The primary partition must be on the first hard drive in the boot order, and if you have more than one user partition (not counting the small drive table partition), you must install to the first user partition. Unfortunately MS doesn't seem to have a clear, comprehensive answer to the issue. I've gleaned the following from various forum responses.
For some reason the installer is date sensitive, so make sure the time and date are correct in the BIOS. Time your next install attempt so it will NOT go past midnight during the installation.
Check your BIOS settings to make sure the drive is listed as a "primary" drive (drive 0, not drive 1) rather than a secondary.
Some people have had problems with the Windows 7 installer on drives that have the Master Boot Record from previous installations. Try a FORMAT /MBR using the Windows 7 install CD. If this doesn't work,
  1. Use the partition command to remove the target partition from the drive to wipe this out
  2. Partition the now unused space and reformat (again!), and
  3. If the partition command or installer has an option to set a partition as primary (or something else), choose primary (disk 0) for the partition you want to use for Windows 7.
If all else fails, use your HP Software Recovery CD to do a complete repartition and reformat. You could use the Windows 7 partition command to do the same thing, but then you would lose the HP System Recovery partition. However, if HP is marking the System Recovery partition as partition 0, it could be causing the problem. In that case, see if HP has an updated version of the CD that includes a fix for this, or do without it and turn it all over to Windows 7.
Dec 26, 2010 | Western Digital WD Scorpio Black...
When i am swiching on the laptop it shows os not found
Dear Friend,
As there is no primary drive in this vaio, it boots form Hard drive. If OS on hard drive is corrupt OR HDD is bad then you will get such massage. Go to set up. Enable external booting option. Try booting the system from USB pen drive ( You have to make a bootable pen drive ). If it boots then you have to replace HDD.
Dec 05, 2010 | Sony VAIO VGN-UX280P Notebook
Dell: Primary hard drive 0 not found Primary
Sorry, but this isn't a good sign. Drive 0 is most likely your main hard drive, and only if you have a second one would you computer ever find anything on Drive 1.
I would check the connections inside from the motherboard to the hard drive, as well as from the power supply to the hard drive.
Here's the manual: http://support.dell.com/support/edocs/systems/opgx60/en/ug/sffabout.htm#1103481
Also, if you boot your computer to the Dell copy of Windows, go through the motions of reinstalling Windows and you probably won't be able to detect any drive to install it on.
You'll most likely need to replace the hard drive altogether. Sorry!
Hope this was helpful for you (even though it was bad news)! If so, please give a rating!
Mar 09, 2010 | Dell Optiplex GX60 PC Desktop
My primary drive 1 an 2 not found how do i fix this
well primary drive is the hard drive from which the OS boots so if it is not detected PC cannot boot so check exactly which drive is not found and you can also check the power cable to the drive which is not found and make sure it gets the power .
good luck.
Jan 06, 2010 | Dell Dimension 2400 PC Desktop
My computer cannot find he primary hard drive
Hi friend,
this is not your system problem. it is your wire problem. You need to change your hard drive cable then try.
Dec 17, 2009 | Dell Dimension 3000 PC Desktop
My laptop has trouble booting. it takes me up to
Sounds like a failing hard drive. Try replacing with a different HD (preferably a known working one that doens't have important data on it) and try installing the OS to it.
-=/ Daft Tech /=-
Oct 22, 2009 | Dell Computers & Internet
Quantum Fireball lct 30gig not recognized in Dell Dimension 3000
Turns out this particular drive needs TWO jumpers on it, to set it to CS. I received it used with a single jumper in the Master position, but after checking the Maxtor/Quantum website, it listed the jumper positions and showed the second jumper. As soon as I installed the TWO jumpers in the correct position, the Dimension 3000 booted right up and let me reinstall Windows. I had scoured the internet for many hours looking for a solution, none solved it until I decided to check the manufacturers website. Always start there!- Solved!
May 18, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Cannot boot my dell dimension 3000
Did you check inside and see if all the cables are attached?
Is the hard drive spinning, it may be bad.
Did this just happen?
Nov 14, 2007 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
694 people viewed this question
Alun Cox
