Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Refridge leaking water inside it...
Hello,my refridgerator seems to have a condensation proplem....the trays at the bottom of fridge fill up with water till its leeking on the floor then we know to dry it up...how do u fix this??
  • kimkrew May 20, 2009
    fridge is collecting water in the bottom drawers but it seems to be coming from the ceiling of the fridge on either side of the light bulb.
  • 90 Answers
Should be a little drain hole in the bottom rear of the fridge. Use a pipe cleaner or somthing similar cos it,s probably blocked. Quite a common problem.
Posted on May 20, 2009
Fridge leaking
check door gaskets are in good condition Open and close door quickly Wait for maybe 10seconds and try and open the door . If the gaskets are working there will ne a marked resistance to opening
May 13, 2013 | Bosch KSU49630 Top Freezer Refrigerator
I have a water leak inside of my maytag fridge and it leaks out onto the floor from the inside. What is the couse of this problem?
Have you checked to see if your condensation tray is too full? The tray will be located at the bottom of the fridge and should slide out easily.
Feb 19, 2012 | Maytag Refrigerators
Why is water is pooling at bottom of the fridge
WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
You have a blockage in your condensate defrost line or the pipe that fill the tray below the refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate back into the air inside your home.
Jan 05, 2010 | Fisher and Paykel Refrigerators
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
There seems to be something leaking from the front bottom of the refridgerator, can it be feron, is it dangeours
freon is a gas at room tempurature. if the fridge is working, then it is probably water condensation. If the fridge is not working, it could be the oil inside the compressor.
Jun 28, 2009 | Refrigerators
The condensate drain begins inside the freezer compartment behind the back panel and at the bottom of the evaporator coils. Every time the refrigerator defrost (about 3 times a day) the water needs to flow out the bottom of that pan in the freezer and into a plastic drain pipe to the bottom of the refrigerator into a pan on top of the compressor or side of compressor. Sometimes the drain is blocked inside freezer and there is a buildup of ice. But sometimes it is blocked near the opening that leads out of the fresh food compartment and then down to compressor tray/pan. If the blockage is near that exit then you will see a trail of water running down the back of the fresh food compartment and settle in bottom. The only solution is to slowly and carefully remove the drain pipe from the back and inside of refrigerator and clean it out. Let me know how you are doing on this and I will be here to help,Thanks Sea Breeze
May 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water in refridgerator interior
sounds to me that your drain line in the back of the refrigerator is clogged up. Take a wire and around 2 gallons of hot water and clear it real good.
Mar 20, 2009 | Camco Battery Fridge Refridgerator Alarm...
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Refridgerator
Unless your fridge has a water supply connected to i.e for an ice maker,t about the only place the water could be coming from the condensate waste pipe.
Inside most fridges near the evaporator (the cold part) is a drain hole so that any condensate can drain out. This flows thru a tube to the back of the fridge. Normally this tube will feed into a tray and will evaporate away naturally.
You could have a look at the back of the fridge to see if this is happening.
Pease remember to rate this solution.
Dec 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
297 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
